Wiring help - Page 5 - Yamaha R6 Forum: YZF-R6 Forums
post #41 of 50 (permalink) Old 06-02-2019, 05:58 PM Thread Starter
Re: Wiring help
Also they shine like shit. Looks terrible.. Threw them out.
Ravager33 is offline
post #42 of 50 (permalink) Old 06-02-2019, 07:02 PM
Re: Wiring help
Well, that's Fleabay...
Intuit is offline
post #43 of 50 (permalink) Old 06-03-2019, 07:56 PM
PrepareForTakeOff's Avatar
Garage
Sorry to hear your lights didn't work the way you wanted. Cheap stuff on ebay can be hit or miss, but i have had success with leds from ebay on many occasions.
I used 3M tape Intuit already mentioned to stick both my led halos inside my housing and my led turn signal light strips with success for over a year. Nothing has come loose, although i imagine one day it will. The 3M tape alows me to remove a light if it goes bad without possible damage to the housing, and i dont have any unneccessary screw holes either. Hot glue was an idea i had, but i was afraid vibration would cause my lights to fall off, so i chose the 3M tape.
PrepareForTakeOff is offline
post #44 of 50 (permalink) Old 06-03-2019, 10:05 PM Thread Starter
Re: Wiring help
Where did you get the 3M tape and was it expensive?
post #45 of 50 (permalink) Old 06-03-2019, 11:52 PM
Garage
You can buy a roll of it at your local oreillys. And no not terribly expensive considering how much you need, but expensive compared to other brands/tape. The stuff works really well though. Roughly 8 dollars for 5 feet of it.
post #46 of 50 (permalink) Old 06-27-2019, 11:19 PM Thread Starter
Re: Wiring help
What do you guys think of something like this? I like the second ones more but just think they will be barely visible in daylight.
post #47 of 50 (permalink) Old 06-28-2019, 01:03 PM
Garage
Looks good and cheap, worth a shot to see if you like them.
post #48 of 50 (permalink) Old 06-29-2019, 02:44 PM Thread Starter
Re: Wiring help
I'll try. So another question, I might try the dual low beam conversion after all and I would appreciate if you guys confirm that I got it right. The manual says that the low beam wire is black/green and high beam is black/yellow. I attached a picture of what I think it should be like.
Name:	Screen Shot 2019-06-29 at 14.33.26 (1).jpg
post #49 of 50 (permalink) Old 07-01-2019, 08:45 PM Thread Starter
Re: Wiring help
bump
post #50 of 50 (permalink) Old 07-02-2019, 12:21 AM
Garage
That is correct.
