XT racing datalogger install wiring help needed - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 5 (permalink) Old 05-28-2019, 01:21 PM Thread Starter
Well... XT Racing is outta business, and their forums and tech resources are gone with them.
I've got a 2008 R6 (stock harness/ecu, not YEC) that I'm trying to install a GPX pro 8 datalogger on, it is not clear which ECU wires I need to tap for:
- Rider throttle position (as opposed to ECU commanded throttle position)
- Engine RPM
I have the service manual, but even from the wiring diagram it is not clear which wire from the TPS is the signal line, or which wire to the instrument cluster drives the rev counter.
I imagine this info would be pertinent to anyone trying to log on these bikes.
Thanks for your time everyone!
mulcibre is offline
post #2 of 5 (permalink) Old 05-30-2019, 03:59 PM
chris0055's Avatar
Bike: 08 R6 Canadian Edition
Re: XT racing datalogger install wiring help needed
I'd love to know this as well.
Based on my understanding and research:
You can find the TPS sensor via step 5) in the bazzaz installation thread:
You can find the RPM (Crank Position Sensor CPS) in the gear indicator installation thread:
Maybe someone with previous installation experience can chip in.
Brembo RCS 19
Pazzo Shortie
MJS Mid + GYTR Slip-on
AGG Blockoff Plates
K&N Air Filter
Dyno Tune FTECU
Vortex Rearset
Core-Moto Brakeline
Ferodo Racing Pads
Puig Clear DB
PZRacing Gear Indicator
chris0055 is offline
post #3 of 5 (permalink) Old 05-30-2019, 10:00 PM Thread Starter
OK, I have a good reading from the TPS on the throttle cable pulley.
I used the white wire running to sensor. I tapped into it at the ECU. I reckon you could also use the white wire with red stripe, since it appears they are redundant, but this is what worked for me.
Still working on getting the RPM readout to work.
mulcibre is offline
post #4 of 5 (permalink) Old 05-31-2019, 04:26 PM
Bike: 2015 R1
Garage
Too bad I don't work at the dealership still. The tech site has a pinout of the ecu plug that says what wire is what
yamahacrazy is offline
post #5 of 5 (permalink) Old 06-03-2019, 03:47 PM Thread Starter
I was able to get everything working!
- GPX 8 is charging when bike is switched on
- RPM taken from ignition coil trigger (2x multiplier)
- rider throttle position taken from throttle cable cam position sensor
- brake pressure switch wired in
Everything is working right, I'll get it finalized and test it out at Thunderhill this upcoming Monday.
I'll post up some pics and a wiring diagram annotation to help out others trying to get this set up!
mulcibre is offline
