2008 R6s - TPS - Help Needed - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 1 (permalink) Old 06-02-2019, 05:33 PM Thread Starter
Bike: 2008 Yamaha R6s
Hello all,
A couple weeks ago I began experiencing issues with my 2008 R6s. After riding about 30 miles, going about 75-80 mph, the bike began sputtering/jerking and I started losing a lot of power. As I began slowing down, and before coming to a stop, the bike stalled.
I sat on the side of the road for about 15 mins, started the bike up, and was able to finish my ride home (about 10 miles) with no issues.
I checked the diagnostics, and pulled codes:
-15 Ė Throttle position sensor
-23 - Atmospheric pressure sensor
-30 Ė Lean angle sensor (I dropped the bike two days earlier taking it off a rear bike stand)
I cleared the codes and wanted see if I could duplicate the codes to narrow down what the problem could be. I began riding the bike again, and it took several hundred miles before I had the issue again. This time, it was just the 15-TPS that came up. I dug through forums and found several people were pulling the TPS and cleaning it with electrical contact cleaner and that helped. I did that Thursday. Friday I had the same issue, TPS.
Something to note, is that this always seemed to occur when the weather was pretty warm, over 80-85F (bike temp 185-190F), and after riding 30-50 miles.
I talked to a gentleman (owner of a local dealership), who said heís never seen a TPS go bad. That it was more likely an ECU, or electrical connection issue.
This afternoon, my husband and I lifted the tank and began going through all the connections. He found one connector that wasnít properly seated. Itís was brown, and unless I really start removing parts of the bike, I canít follow where it leads to.
Iíve tried looking through diagrams online to see where/what this connection leads to, but Iím struggling.
Could someone help me out here? What would this connector lead to? And could it be the cause of what Iím experiencing?
RiggsyR6 is offline
