Oil Pump Cover Leak, Bolt Broke Thread - Yamaha R6 Forum: YZF-R6 Forums
 1Likes
  • 1 Post By 03r6Raven
post #1 of 8 (permalink) Old 09-11-2019, 06:36 PM Thread Starter
06 r6
Hey Guys,
I bought a used 06 r6r. I noticed oil leaking from the oil pump cover so I took it apart to figure out why. I've attached a picture of what I found. I'm sure the bike was dumped before, but it looks like the bolt actually ripped out the part of the bike that holds the thread. I have no idea what to do short of weld oil pump cover on and weld the holes closed, which if it ever went down and broke again would be a problem.
Thanks in advance for any advice/suggestions!
ID:	363298   Click image for larger version
post #2 of 8 (permalink) Old 09-11-2019, 07:22 PM
03r6Raven's Avatar
Bike: 2018 Blue R6
Re: Oil Pump Cover Leak, Bolt Broke Thread
find a really really good tig welder and have him add material so you can retap that section. don't weld the cover on.
Straight Success likes this.
03r6Raven is offline
post #3 of 8 (permalink) Old 09-11-2019, 08:11 PM
The cover and block are probably distorted a little... bent. Get a new gasket and pickup some RTV gasket maker silicon sealant from the auto parts store. The torque spec on those bolts is surprisingly low, but if what's left of the threads doesn't hold it, you'll have to do as 03r6Raven has suggested. Unfortunately there's nothing for an epoxy resin such as JB Weld to hold on to, so that option is likely out. (...and you don't want that breaking loose and floating around in your timing chain cover)
Intuit is offline
post #4 of 8 (permalink) Old 09-11-2019, 11:15 PM
PrepareForTakeOff's Avatar
Garage
You could also have a nut with the same thread pitch/size welded on in that location, however that would require removing what is left and making sure the nut lines up with the cover hole.
PrepareForTakeOff is offline
post #5 of 8 (permalink) Old 09-15-2019, 11:05 AM Thread Starter
06 r6
Thanks for all the info! I have a cousin that does aluminum welding. Said we can clean it out well, build up the aluminum and then tap it, like what was suggested!
Said it shouldn't take too long!
I did try the rvt and new gasket, still leaking out of it unfortunately.
post #6 of 8 (permalink) Old 09-16-2019, 05:29 AM
Touchdown!
Straight Success's Avatar
Bike: 2012 R6
Send a message via Skype™ to Straight Success
Yup. A good ol' cleaning to get the oil gone, a few dabs of some good filler rod, tap it to the correct size, and use a file or sandpaper with a block to make sure it's even (probably up to 2000 grit or so), and bolt it back up. Don't rush it.
Chillin'... while the Lord watches over me!
I love my R6, but...there's no buts...
Straight Success is offline
post #7 of 8 (permalink) Old 09-16-2019, 09:20 AM Thread Starter
06 r6
Will do! Any advice for worrying about aluminum and junk getting into oil pump area? Just run the bike for 5 min after and do an oil change?
post #8 of 8 (permalink) Old 09-16-2019, 08:00 PM
Mask it all off before starting any work.
Intuit is offline
