2008 R6 front brake pressure - Yamaha R6 Forum: YZF-R6 Forums
 1Likes
  • 1 Post By Straight Success
post #1 of 5 (permalink) Old 09-16-2019, 01:57 AM Thread Starter
Parked my bike for a few months and noticed the front brake pressure has gone down. What could be the cause?
KayJay is offline
post #2 of 5 (permalink) Old 09-16-2019, 04:54 AM
Touchdown!
Straight Success's Avatar
Bike: 2012 R6
Send a message via Skype™ to Straight Success
Re: 2008 R6 front brake pressure
Could be a host of things.
Have you squeezed it multiple times until it felt back to normal/your liking? If not, describe the feeling.
It could be air/moisture in the system. It could be attributable to the weather. Brake fluid will be have slightly differently at 90 ℉ comapred to 50 ℉. How old is the brake fluid? Do you see any leaks?
Chillin'... while the Lord watches over me!
I love my R6, but...there's no buts...
Straight Success is offline
post #3 of 5 (permalink) Old 09-16-2019, 06:52 AM Thread Starter
I had recently changed the entire fluid, bled out the system before putting the bike away. As suggested, I have pumped the lever a few times to get some pressure into it. However, I have one those after market levers which are adjustable and it now requires the highest position the get any reasonable pressure feel.
KayJay is offline
post #4 of 5 (permalink) Old 09-16-2019, 08:33 AM
Touchdown!
Bike: 2012 R6
Pressure bleed it with a compressor, take it around the block slowly, and see if it changes.
If that doesn't help, put the lever on the lowest setting, pull the brake in, put a zip tie around the level and throttle in a full braking position, and let it sit like that over night.
Gorbonosov likes this.
post #5 of 5 (permalink) Old 09-29-2019, 10:27 PM
When's the last time you cleaned the calipers? If you cleaned them make sure you grease the pistons so they move across the seals uniformly. You may just have stuck pistons
