R6 with R1 motor??? - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 26 (permalink) Old 10-15-2003, 09:01 AM Thread Starter
R6 with R1 motor???
Okay. So I want an R1. Unfortunately, because I am under 25, my insurance company would require me to pay $8000 CDN. So, I thought I would insure an R6, and then stick an R1 motor in afterwards. This is *technically* legal where I live.
Yes, I know that the R6 is fast enough. Yes, I know that I will be imbalancing the bike by doing this. I want to do it anyway.
So: my question: how much, exactly, does as R6 motor weight? & how much does an R1 weigh? And what are the physical dimensions of each? And has anyone on this forum heard of doing this to an R6? In your opinion, is the power of an R1 too much for an R6 frame? & do you think the R6 carbs will fit or will I have to use R1 carbs?
I am thinking of doing this to a slightly older model. Say, 98-99. If there is some particular Yamaha-related problem to this project, I would also consider a 929/F4 or GSXR-1000/600 transplant.
Thanks!
-Spiderbyte
spiderbyte is offline
post #2 of 26 (permalink) Old 10-15-2003, 09:37 AM
I have seen the gsx-r 600/1000 swap done. The bike was not that mutch faster than a regular 1k tho. I understand what you are doing for the insurace to. 8k for insurance is a good rapping!
For the carbs you would need to stay with the r1 set up. I don't see the R6 ones delivery the propper fuel. I am not sure ont he wieght differences in the motors, but it should not be more than 15-20 pounds I would think.
The frame should handle just fine for a straight line, but in the twisties will probably flex a good amout.
-DJ1298
The great dj1298, I invented the intarweb, now pay me.
dj1298 is offline
post #3 of 26 (permalink) Old 10-15-2003, 09:41 AM Thread Starter
Are you in contact with the gsxr guy? Did he mention any particular difficulties, do you remember?...
What do you mean "in the twisties will probably flex a good amout"?? Flex?
post #4 of 26 (permalink) Old 10-15-2003, 09:48 AM
I did not get details on the swap, just saw the swap after it was all done.
I could see the R6 frame flexing when you role on the throttle mid apex, or try some jerky throttle closings/openings. This would be exagerated more when leaned over than upright on a straight away. I would get a steering damper first off with this swap.
dj1298 is offline
post #5 of 26 (permalink) Old 10-15-2003, 09:53 AM Thread Starter
Mmhmm- and of course will need a serious brake upgrade, too-
post #6 of 26 (permalink) Old 10-15-2003, 10:02 AM
Send a message via MSN to penfold
Some wave rotors up front and some better pads and you'll be fine. the R6 and R1 run the same rear brake, well, '03 R6's and up as well as '02 and up R1's. I believe that to be the case anyways.
penfold is offline
post #7 of 26 (permalink) Old 10-15-2003, 10:49 AM
You also have to check the width of the motor because it will sit between the frame members and if it is too much wider, will not work
Check engine mounting angle and mount position.
Check lower engine dimensions too, brecause in some areas on the R6, the bodywork leaves little room for anything larger.
Sounds like a lot of work and a lot of modification, fot for *000 a year\, it may be worth it.
It will never be as good or as stable as the r1 (or even the original r6)
The R1s are completely different.
Gixxers may work better because the frames might all be the same (I think they get them out of cereal boxes too, but I'm not sure)
"Treat it like you love it , ride it like you hate it"
PEOPLE WHO THINK THEY KNOW EVERYTHING ANNOY THOSE OF US THAT DO!
jasamb is offline
post #8 of 26 (permalink) Old 10-15-2003, 12:38 PM
I thought it was out a Crackerjacks Box? What's the difference....crap is crap...
penfold is offline
post #9 of 26 (permalink) Old 10-15-2003, 04:02 PM
Jeffsy's Avatar
I doubt it'll fit & if by chance it does you could have problems down the track with a cracked frame ? If you look at the size of the frame of the R1 compared to the R6, the R1 is way beefier around the motor than the R6 to handle the extra power.
Also if you crash & the insurance company checks it out & finds you've got an R1 motor in it they'd null & void your insurance & you'd not only have to pay for everthing yourself but trying to get insurance again would be virtually impossible.
Sorry to "rain on your parade"
Jeffsy is offline
post #10 of 26 (permalink) Old 10-16-2003, 06:11 AM Thread Starter
Thank you for your advice, Jeffsy.
1st R6 Ride, Comparison to 02 R1 eduardobibm General Discussions 6 06-11-2007 02:53 PM
R6 / R1 Stealth Sprocket Christmas SUPER SALE ! SpidermanSS Site Sponsored Specials 15 11-28-2006 10:16 PM
R6 vs. R1 long General Discussions 21 11-18-2006 09:52 AM
04 R1 wheels on 06 R6 ra6hc General Discussions 5 09-14-2006 09:48 AM
R6 Tail on 02 R1? xdonniedarkox Garage / Mechanical Help 3 05-09-2006 10:08 AM
