2017 vs 2019 FTECU R6 Images - Yamaha R6 Forum: YZF-R6 Forums
 1Likes
  • 1 Post By rusky
post #1 of 6 (permalink) Old 04-10-2019, 06:35 PM Thread Starter
rusky's Avatar
I'm in the process of building my 2018 R6 for the supersport 600 class. I picked up the FTECU side tune kit along with their QS/Autoblipper.
The first step of the process is to flash a stock unlocked image onto the ECU. The FT Suite provides stock maps for the 2017 and the 2019, but not the 2018. I wasn't aware of any significant changes for 2017+ so having the option to run 2 stock maps kinda threw me off.
Which one should I use? What's the difference?
Thanks!
rusky is offline
post #2 of 6 (permalink) Old 04-14-2019, 11:05 PM Thread Starter
rusky's Avatar
Re: 2017 vs 2019 FTECU R6 Images
Follow up on this topic. The main difference between the 2017 and 2018/2019 maps is that the more recent ones add 0.5% throttle during start up. This helps eliminate the cold start issue that the 2017s had when stock. I'm now running the 2019 unrestricted map with active tune and autoblipper.
yamahacrazy likes this.
rusky is offline
post #3 of 6 (permalink) Old 08-24-2019, 09:27 PM
YZFR6... ooodles of HP
mordantly's Avatar
Bike: 2017 YZFR6HC
I had to have my '17 recall flashed for the hard start. She still sometimes has hard starts cold or hot. You have the '19 map on an '18 ecu?
MoRdAnTlY [Mr. Wolf '91-'19]
2017 YZFR6HC....2002 ZX9R....1993 KTM 300EXC....1983 VF750F....1981 GPz 550D1 (x2.5)....1975 DT400B....1972 LT-2....1971 SL350K1....1967 CT90K1....Plus more projects
mordantly is offline
post #4 of 6 (permalink) Old 08-24-2019, 09:46 PM
Freemaysin's Avatar
Where at, yami dealer?
Freemaysin is offline
post #5 of 6 (permalink) Old 08-24-2019, 09:49 PM
mordantly's Avatar
Bike: 2017 YZFR6HC
Yes during the "setup" final assembly prior to taking delivery.
post #6 of 6 (permalink) Old 08-24-2019, 10:12 PM
Freemaysin's Avatar
I boguht mine w/ 1300 used from a yami dealer, but i still have them as well. Not sure if its been done, i'll go double check anyways. It got more prominent full after full system exhaust/tune
i usually turn the bar killswitch on, before ignition, then it either starts fine in like 2 cranks, oi give it 5% throttle and she rolls.
WTB: 2017 Yamaha R6: Left Bar end, Clutch lever, Stator Cover etc. BlackDemon Bikes + Parts + Gear Wanted 4 04-22-2019 07:13 PM
2017 R6 shared parts with previous edition? nickon2 General Discussions 6 02-15-2019 11:31 AM
2017 R6 Graves full exhaust and FTEcu maps DefiantDeity Exhaust and fuel delivery 3 12-24-2018 09:15 PM
2017 R6 Headers Suggestion ggwill Exhaust and fuel delivery 1 10-02-2018 01:45 PM
R6 2017 speedo meter US can fit UK? Rewki333 Garage / Mechanical Help 0 09-05-2018 04:47 PM
