2012 Pump not priming need someone to test wire - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 2 (permalink) Old 04-21-2019, 06:51 PM Thread Starter
My R6 is nice
Aproductions's Avatar
Bike: 2002 R6
On my 2012 r6 I can manually Hotwire the pump and it primed so I know the pump side is fine. I tested the red wire that runs to the fuel relay under the seat and it has 12v. To my understanding the relay then is supposed to switch power to a red/blue wire that runs to the pump. I tested that wire and has no V there. That should mean the fuel relay is bad but would love for someone to take their seat off and see if they have 12v coming out of the red/blue wire on the fuel relay harness under the seat. Please and thank you
Alex Romanishan-2002 R6
Mods:
D&D Slip-on
Zero Gravity Dark Smoked windscreen
Michelin Pilot Power 2CT Tires
Rizoma Sportline grips
Rizoma Conical bar ends
Proton Flushmount signals
Led rear signals
Custom led relay
EBC-HH brake pads
Fender eliminator
AVS knockoff brake levers
Core ss brake lines
Gear:
Arai RX-Q (Ace Blue)
Aproductions is offline
post #2 of 2 (permalink) Old 04-22-2019, 07:37 PM
Bike: 2015 R1
Garage
Don't forget you only get power for 3 seconds for priming. You have to keep cranking tbe engine to get power.
yamahacrazy is offline
No power at fuel pump bmeyer15 Garage / Mechanical Help 10 08-27-2018 11:55 AM
R6 ignition wire for alarm install??? mytrickR6 How To's... 7 06-28-2004 02:30 PM
