ECU Tuning, send it out or do it yourself? (WoolichRacing?) - Page 2 - Yamaha R6 Forum: YZF-R6 Forums
 2Likes
post #11 of 14 (permalink) Old 02-24-2019, 07:17 AM
Just lean harder...
Phrozen's Avatar
Bike: 07 R6s
Originally Posted by yamahacrazy View Post
"Snip" I just hate the fact you can't use it offline and it will not tether from a phone's internet.
You can Hotspot your phone to your PC and then you can use FTecu as I have done it plenty using my IPhone for internet access.
I can also say the ActiveTune from FTecu is freaking awesome!! I installed a Nitrous setup on a 2017 R1 using a spray bar manifold in the airbox. The AFR held true and steady at 13.0 even when sprayed with a 20 shot of Nitrous. Power went from 187hp to 202hp!!
FlashTune does have its quirks and bugs but after you figure all that out it's an awesome tuning tool.
Phrozen is offline
post #12 of 14 (permalink) Old 02-24-2019, 01:49 PM
Bike: 2015 R1
Garage
Re: ECU Tuning, send it out or do it yourself? (WoolichRacing?)
Originally Posted by Phrozen View Post
You you Hotspot you phone to your PC you can use FTecu as I have done it plenty using my IPhone for internet access.
ahh ok. I seen someone complain a few years ago 2015 or 16 and said that he couldn't get it to work from his phone tethering. it said the software can't open.
the woolich software can do auto tune but it doesn't do it continuously like yours. it records all the info from a few rides and uses it to build a static map. it does a great job of it. I can feel a difference in the midrange. it also allows you to set a target afr. so if I wanted it at 13 (I actually did) it tunes the map to use 13 where it needs to. it also eliminated 100% of the popping on my R1. I kind of liked the gurgling pop on downshifts and it's gone now
the R1 just sounds so amazing banging and popping on down/up shifts. the R1 stock doesn't even open the throttle to 100%. I made sure that got fixed too
yamahacrazy is offline
post #13 of 14 (permalink) Old 02-24-2019, 05:33 PM
WTF Over
Got a quote from Bauce today, have bike one day,,, very reasonable priced... would like to see before after dyno..
masterblaster is offline
post #14 of 14 (permalink) Old 06-24-2019, 02:50 PM
My R6 wheelies me.
@R6_Arel's Avatar
Garage
I have an 05 R6 and I'm trying to find a way to tune the ECU a bit. It's not a race bike at all, it's a stunt bike.
I'm not looking for more power. I'm trying to change the On/Off feeling the throttle has when I'm rolling on. I've heard slide stops help with that, but hunting down a set of graves now is almost impossible. I've found some DIY post here that show you how to make it out of piping but that's just too complicated for me. I'm thinking about just removing the springs and gluing the stops all the way back. I'm also swapping my throttle tube for a 2015 FZ tube because they have a longer twist so it'll be smoother instead of being fast to full throttle. The people with newer FZs do the opposite and change it for the R6 tube to have a shorter and faster twist to WOT.
Anyway. Is there a way for me to tune my ECU for a smoother roll-on from closed to slightly open throttle? And to reduce engine braking a bit?
I have a PC3, K&N filter, full Leo Vince exhaust.
@R6_Arel is offline
Careful tuning ecu 04 r6 with woolich.. cbrentb Exhaust and fuel delivery 1 04-06-2018 09:55 AM
anybody send there xbox 360 in for service? Egon Off Topic Talk 10 01-05-2008 08:28 PM
Where to send the $$ for forum stickers? deserteaglepoint50 General Discussions 1 02-23-2005 04:32 PM
