ECU Tuning, send it out or do it yourself? (WoolichRacing?) - Yamaha R6 Forum: YZF-R6 Forums
 2Likes
post #1 of 14 (permalink) Old 04-15-2018, 06:26 AM Thread Starter
Bike: R6
Howdy,
I'm considering removing some of the oem restrictions on my '07 R6 and I'm wondering if its worth sending the ECU out to have this done, or try doing it myself?
Has anyone here used the Woolich Racing ecu tuner? if so, what were your results?
Any info would be appreciated.
Thx
Tazmool
I've upped my post count,
Up Yours!
Tazmool is offline
post #2 of 14 (permalink) Old 04-15-2018, 08:59 AM
Bike: 2012 R6
Garage
Re: ECU Tuning, send it out or do it yourself? (WoolichRacing?)
If you plan on getting a full exhaust wait until then because you can get a tune to match it. But even with stock exhaust there's a lot to gain from a flash on this bike. Check out Bauce Racing out of NJ. They have a good price and are very helpful. I just recently got a full exhaust and flash through them and it was a great experience.
fulltuckchris is offline
post #3 of 14 (permalink) Old 04-15-2018, 01:26 PM
I am a Super Saiyan.
Bike: Yamaha R6
THIS!^
It's better to send it in then to do it yourself from what I've read on the forums. If you check out Bauce Racing reviews here on the forum, you'll see why everyone chooses them.
naturalbrawler is offline
post #4 of 14 (permalink) Old 04-15-2018, 02:53 PM
vancouverite
Bike: 2005 r6
how much difference does it make?
jsk14 is offline
post #5 of 14 (permalink) Old 04-15-2018, 03:18 PM
Bike: 2015 R1
Garage
it's debatable. you can do more with the flash than you can with a piggyback system such as a power commander.
not only can you modify the fuel mapping you can adjust things that yamaha made adjustable in the ecu.
some bikes have more than others. but some examples are fan temp adjustment when it comes on and goes off. you can change what rpm the upper fuel injectors start working, what rpm the intake track changes length. ignition timing, turn off the trouble code warning light for the exup valves. and a few other things I can't remember. some of the newer bikes 2017 and up you can use the flashing software for diagnostics. since starting in 2017 the euro 4 emissions put a stop to the bike having a built in diagnostics. (thank europe not usa for ruing the bikes).
I chose to buy the flash kit myself. now I can run a auto tune at any time and change the fuel mapping. or make any changes I want to everything else. which on the R1 is a lot of stuff. I went with woolich because unlike FTECU you don't need internet access to use it. (dumb as hell move FTECU).
so keep that in mind if you go with ftecu, if you're at a track and have no wifi you can't do anything to your bike. especially if you're having some kind of issue and need to change the settings. you're shit out of luck.
so long story short, yes it makes a difference. will it make your bike gain 10 hp? no. could you theoretically gain 10, yes as long as you know what you're doing and have access to a dyno.
however, there is a risk with flashing a ecu. not many people have problems but it has happened. some yamaha's have a immobilizer anti-theft system. if it locks up it bricks the ecu while being flashed. a company in england used to advertise they can fix the ecu if you brick it. I don't recall their name.
some guy on this forum bricked his ecu on a 2004. I honestly never heard of a 2004 being able to be flashed so it may be riskier to try it to ones below 2006. I have a 2015 R1 and it didn't flash properly once. the bike would not start. I flashed it again and it was functioning normal. so it can happen and it can **** it up.
naturalbrawler likes this.
yamahacrazy is offline
post #6 of 14 (permalink) Old 04-15-2018, 07:58 PM
Bike: 2012 R6
Garage
I sent mine in to Bauce Racing but I installed it alongside a full exhaust, block off plates, air filter, so it's hard to say what really contributed to the difference. This being said I have experienced a VASTLY smoother and more responsive throttle and less engine braking (stock engine braking is over the top, it's much better now). I also had them disable EXUP and AIS, increase my idle to 2,000rpm, lower the fan trigger temps, and set the fuel mapping to my specific bike year and exhaust/air intake setup. I was pretty happy with the way the bike felt when I got it. Now that I've got the flash and the exhaust I am absolutely over the moon in love with it. Definitely recommend the flash, absolutely worth the $$$. Especially if you have mods that require a tune.
post #7 of 14 (permalink) Old 04-24-2018, 08:25 PM
i am 99 % sure the responsivness is from the ecu mod. added the full exhaust and air filter had made my bike jerky until the ecu flash (not dramatically, but the fix was very noticible once the ecu was mapped)...
modspec is offline
post #8 of 14 (permalink) Old 02-20-2019, 02:12 PM
Donald Campbell's Avatar
Bike: 10 r6
I bought a ftecu kit, but Iím still may send it to BAUCE for the enitial flash. I may even get a second echo just to mess around with.
Donald Campbell is offline
post #9 of 14 (permalink) Old 02-22-2019, 04:12 PM
Bike: 2015 R1
Garage
Originally Posted by Donald Campbell View Post
I bought a ftecu kit, but I’m still may send it to BAUCE for the enitial flash. I may even get a second echo just to mess around with.
why? you have access to a few maps you can try. and you can download maps from other users. ftecu has maps they've made and tested on bikes that get raced. so the maps should be pretty decent. if you send it out you will have to pay another $150 when you just spent $400 for the kit. it's not hard at all to flash. follow the on screen instructions in the software and it's idiot proof. if you've ever sent maps to a power commander it's basically the exact same procedure. except it takes a little longer for the software on your laptop to erase and flash the ecu.
post #10 of 14 (permalink) Old 02-22-2019, 04:19 PM
Bike: 2015 R1
Garage
BTW if anyone is still on the fence with woolich over FTECU. I'm going to have to say go with FTECU. woolich has been great with their support but they took their forum down. well it's there but it has no sections for users to discuss anything. they said no one was helping others with issues so they took it down. that's hogwash. now no one can chat and share info about the system and talk about tuning etc. this made me pissed off when I noticed it gone. so next bike i'm getting FTECU stuff. it has way more users and a forum. I just hate the fact you can't use it offline and it will not tether from a phone's internet.
r6Ben00 likes this.
Careful tuning ecu 04 r6 with woolich.. cbrentb Exhaust and fuel delivery 1 04-06-2018 09:55 AM
anybody send there xbox 360 in for service? Egon Off Topic Talk 10 01-05-2008 08:28 PM
Where to send the $$ for forum stickers? deserteaglepoint50 General Discussions 1 02-23-2005 04:32 PM
