LED Headlight Cap Adapters - Page 2 - Yamaha R6 Forum: YZF-R6 Forums
 3Likes
post #11 of 30 (permalink) Old 03-18-2019, 04:40 AM
Life is short
Israel7970's Avatar
Bike: 2007 Yamaha r6
Re: LED Headlight Cap Adapters
They look awesome
Israel7970 is offline
post #12 of 30 (permalink) Old 03-18-2019, 10:08 AM Thread Starter
Originally Posted by Israel7970 View Post
They look awesome
Dude! Thank you
nezr6 is offline
post #13 of 30 (permalink) Old 03-18-2019, 04:00 PM
Originally Posted by nezr6 View Post
That looks awesome. Man the clearance there is tight. I want to ask, did your LEDs have fans? It seems that one’s that do cause moisture in the lens like a kid breathing his hot breath on glass. It seemed that so far the only way to mitigate the issue is unplugging all 4 breather/vent caps on the back to let the hot air vapor out. But no full preventative measures yet.
Anyone, ideas?
Drop a few dessicant packets in the housing. Open them up only on a day with low humidity.
- good thinking!
Intuit is offline
post #14 of 30 (permalink) Old 03-18-2019, 06:41 PM
PrepareForTakeOff's Avatar
Garage
Yeah the leds i installed do have fans. I have not had any issues with moisture inside my headlight housing. Of course, when i did the leds, i did an H4 conversion and installed halos and turn signal leds inside the housing also, but thats a different topic for a different thread. However in doing all that it forced me to removed the lens and then reseal it when i put it back on.
My housing is dry inside 24/7.
PrepareForTakeOff is offline
post #15 of 30 (permalink) Old 03-18-2019, 06:42 PM
Garage
And thanks for the comments guys.
post #16 of 30 (permalink) Old 03-19-2019, 02:50 PM Thread Starter
- good thinking!
Thanks for the suggestion, Just bought it. I’ll try it and see the outcome. I’m curious on the effectiveness. Like how much water can be absorbed over a given time per whatever sealed volume.
nezr6 is offline
post #17 of 30 (permalink) Old 03-19-2019, 02:57 PM Thread Starter
Interesting. Quite the setup. Gooot to hear not all LEDs cause moisture.
nezr6 is offline
post #18 of 30 (permalink) Old 03-19-2019, 06:03 PM
Thanks for the suggestion, Just bought it. Iíll try it and see the outcome. Iím curious on the effectiveness. Like how much water can be absorbed over a given time per whatever sealed volume.
was nice enough to perform an experiment on request -
I was thinking, abrasion may eventually wear a hole in those packets, much like it's worn holes in the jumper-cable bags that are in my trunk. (I've since wrapped them in cloth rags.) Then you'll have a minor mess inside those housings. It may be a good idea to use a little folded-over packaging tape to try and secure the packets. (of course if they're taped down from the top side, it'll mostly block them from absorbing moisture)
Intuit is offline
post #19 of 30 (permalink) Old 03-29-2019, 07:22 AM Thread Starter
Things worked out great. I used a hair dryer to evaporate the condensation off the lens then heated up the desiccant packets and put them in the housing and let sit over night. Looks good. Thanks for that.
nezr6 is offline
post #20 of 30 (permalink) Old 06-05-2019, 09:11 AM Thread Starter
Hey just a follow up to this problem. It seems that the LEDs I used were the culprit. A combination of the way the fans blew along with the structure of how the reflectors sat guided the hot air right onto the lens causing the problem. By simply switching to another LED headlight I no longer had the problem. The new LEDs I got has the fans blow the hot air out the rear.
nezr6 is offline
Dual Headlight Setup nezr6 General Discussions 20 12-16-2018 05:31 AM
Headlight mess jerzee6 Appearance and Exterior Mods 3 06-25-2004 01:27 AM
Headlight mess jerzee6 Appearance and Exterior Mods 0 06-20-2004 02:45 PM
My Headlight Mod SilverR6 Appearance and Exterior Mods 58 06-02-2004 02:45 PM
