LED Headlight Cap Adapters - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 25 (permalink) Old 03-04-2019, 08:09 AM Thread Starter
Hey there,
I've been on and off this forum throughout the years and am either buying or selling parts for my shop. I also have asked for help or gave help in the general discussions based off my experience. This is my first post in the product reviews section though so please if I am not within the guidelines just let me know.
In regards to the product, I really like the effect that LEDs have. They are bright, more efficient (draws less current), and come in different color outputs across the temperature spectrum such as 6000k. It seems that a lot of people are upgrading or wanting to upgrade to LEDs now. The issue is that with most LEDs, the back of the LED headlight sticks out pass where the headlight cap screws back in. So a lot of riders have the same issue of riding without caps on the back and when it's humid out, the lenses would have condensation inside them. The amount of moisture over some time may affect the terminals and electronics inside. I decided to develop these cap adapters for LEDs that are extended in the back so that they screw in just like the original ones but are also able to fit the entire LED in the housing. I 3D printed prototypes to get it all started, but sine a lot of people were interested in it I ended up getting them professionally made. The sealing is perfect and it got rid of any condensation. Later I included selling them in my motorcycle business. Attached are some pictures showing the concept and comparison.
I just hope that this will reassure people that they can buy LEDs without worrying about the physical constraints LEDs carry, and not limit or guide people away from being able to upgrade their headlights to see better and be more aware as well as safe.
ID:	360114   Click image for larger version
ID:	360116   Click image for larger version
ID:	360118   Click image for larger version
nezr6 is offline
post #2 of 25 (permalink) Old 03-04-2019, 10:56 AM
nova r6
tdoss1980's Avatar
Bike: 05 r6 Camo/Orange
Re: LED Headlight Cap Adapters
Can you PM me more info, or a site to get them. I have a 2005 and 2009 both with LED and would really like to cover those holes back up
March 2014 Bike of the month
tdoss1980 is offline
post #3 of 25 (permalink) Old 03-04-2019, 02:40 PM Thread Starter
Yeah, of course.
nezr6 is offline
post #4 of 25 (permalink) Old 03-04-2019, 09:22 PM
Are the caps the same between the quads and duals?
Intuit is offline
post #5 of 25 (permalink) Old 03-05-2019, 02:04 AM Thread Starter
If you mean between the R6s and R6r, yes. The OEM number for the caps on both headlights are the same.
nezr6 is offline
post #6 of 25 (permalink) Old 03-08-2019, 05:43 PM
cedstoray2@gmail.com's Avatar
How do I get a set of these? Just installed my LEDs and as you said, they stick out past the dust cap
post #7 of 25 (permalink) Old 03-16-2019, 06:16 AM
I saw the DRIM setup on the site. I just have black electrical tape over the upper part of right-hand side lamp, allowing me to run it full time without blinding drivers. Can you develop and sell a professional looking "masking" alternative? Kind of like a peel and attach "wrap" for the headlamp(s), masking off the top part and thus allowing to keep the full luminance.
Question about the cap adapters: I have R6S model with the quad lights. Do the cap adapters fit without hitting the left/right "console panel" fairing behind it?
Intuit is offline
post #8 of 25 (permalink) Old 03-16-2019, 08:10 PM Thread Starter
I noticed we chatted a bit about the DRIM and your taping method in another thread. That’s a good idea, but I don’t think a professional looking masking alternative will carry many benefits over tape if you think about simplicity, availability, and cost. Especially with a big investment in R&D just to launch a new product.
In regards to the R6s, you’re correct. It looks like those ram air covers ride up to the back of the caps pretty tightly. Although the cap adapters fit the housing, the plastics wouldn’t allow it. So an R6s using these may not be ideal. I need to confirm this as we haven’t had an R6s in ever since the caps were made. Thanks!
nezr6 is offline
post #9 of 25 (permalink) Old 03-16-2019, 10:18 PM
PrepareForTakeOff's Avatar
Garage
In regards to installing led headlamps in the quad light bikes.
The leds i purchased also had the heat sink stick out past the housing not allowing the dust cap to screw on. At first i modified the original dust cap, and then it dawned on me that home depot sells FERNCO plumbing caps. I believe the correct diameter was 4". They were less than 10 bucks each and they look nice. Clamp them on with a large hose clamp and problem solved.
PrepareForTakeOff is offline
post #10 of 25 (permalink) Old 03-17-2019, 04:30 AM Thread Starter
That looks awesome. Man the clearance there is tight. I want to ask, did your LEDs have fans? It seems that one’s that do cause moisture in the lens like a kid breathing his hot breath on glass. It seemed that so far the only way to mitigate the issue is unplugging all 4 breather/vent caps on the back to let the hot air vapor out. But no full preventative measures yet.
Anyone, ideas?
nezr6 is offline
Dual Headlight Setup nezr6 General Discussions 20 12-16-2018 05:31 AM
Headlight mess jerzee6 Appearance and Exterior Mods 3 06-25-2004 01:27 AM
Headlight mess jerzee6 Appearance and Exterior Mods 0 06-20-2004 02:45 PM
My Headlight Mod SilverR6 Appearance and Exterior Mods 58 06-02-2004 02:45 PM
