CustomLED Integrated Tail - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 20 (permalink) Old 08-13-2003, 09:14 AM Thread Starter
Initial Thoughts
One of the few flaws, to me anyways, of the '03's is the mudflap/rear blinker combo. To remedy this situation, I choose a CustomLED (
) Integrated tail kit. My chosen vendor suggested McCoy Motorsports as the outlet of choice for the purchase since they were running a special on them. I paid $179.00 plus $10 for shipping for a total of $189.99 (yes, I know, fantastic math skills! what else did you expect 6 years of college to impart upon me?). There were many other vendors out there that had similar kits but I chose this one as I had seen a animation of it somewhere and the blinker lights are offset a bit to the outside of the brake lights on their respective sides so it gives it a bit of an animated look as if the blinker is kinda of moving in that direction. Aside from that, it's also much brighter then the stock LED's. So by installing this, I could clean up the rear quite a bit and make room for my pipe as well. When I received the piece (2 days), it was quite the looker. Lots and lots of LED's, good directions and some real nice waterproof wire splicers. I couldn't wait to get it installed.
The Install
After reading through the directions once, I set about installing it. Now, one quick word. You'll need some kind of rotary tool (ala Rotozip, Dremel, etc) and a cutting wheel. I went to Home DePot and looked through their tool corral for Dremel cutting wheels. I came upon a small canister of them, about 36 of them for $5.99 that were less than an 1/8 in width (#409 wheel I believe). Then I saw a cutoff wheel pack that included the same canister, plus another one of different sizes and about 20 other sizes (2 each of those) for $9.98 so I grabbed that as you never know what other uses you might have for them... Just some shopping advice... what can I say, I'm a cheap ass.... Anyways, once you get the passenger and drivers seats off, you can unbolt the stock mudflap from the trunk and then proceed to remove the plastic pop rivets from the undertail by pushing in the center of them until they "pop" and then pull them out. Drop the undertail down and let it hang for the moment. Then remove the one allen bolt that holds the tail on right above the tail light assembly (and 2 smaller pop rivets at the drivers seat). You can now remove the tail and start disconnecting the wires. Now you can follow the directions included with the piece. The hardest part is cutting off the lense. Just be slow and steady with the cutting wheel and you'll be straight. Don't cut to far through otherwise it'll make remounting the lense a nightmare. Luckily, you can "feel" the change in the materials (lense vs. the backing plate) when you cut throught the lense. Work your way around the lense, then pry off with a flat head screw driver, but be gentle. With the supplied splicers, connections are quick and simple. The whole process probably took about an hour. I used clear silicone sealant (hi grade) to re-attach my lense. Let the lense sit up over night and then re-install.
Post-Installation
The light looks great! Cleaned up the back end so much it's unbelievable. It's also very bright. Almost has a strobe effect to it when the blinkers are on, especially with the higher flash rate due to the higher efficiency of the LED's (fronts also flash faster). What more can I say? The piece was really well built, easy instructions made for an easy install, and it looks great when it's operating. Other wise, no one would know you put it in. Just looks like you unbolted everything from the back of the bike. Now if my pivot kit would just get here!
If any one has any questions feel free to contact me!
Penfold
penfold is offline
post #2 of 20 (permalink) Old 08-13-2003, 10:29 AM
JL
Any pics? I have been thinking of doing something like this.
JL is offline
post #3 of 20 (permalink) Old 08-13-2003, 12:05 PM
Guest
Posts: n/a
Ya, I'll post some pics when I get back from vaca in Vancouver. I also have a vid of it in action that I hope to get up on site.
post #4 of 20 (permalink) Old 08-13-2003, 12:09 PM
Guest
Posts: n/a
post #5 of 20 (permalink) Old 09-03-2003, 04:32 PM Thread Starter
Here's the vid of it. It's in the download section if you haven't checked it out already. Sorry for the quality. Had to use the video function on my digital camera....
penfold is offline
post #6 of 20 (permalink) Old 10-23-2003, 12:30 AM
dam i wanna see ,but is it just me or is your pic not working ??
All-bust is offline
post #7 of 20 (permalink) Old 10-23-2003, 01:57 AM
no pen' its not workin.if u want to c the finished job with pivot kit fitted,my 'old' bike is in IMAGES,MEMBERS RIDES,page 8
BRAVO is offline
post #8 of 20 (permalink) Old 10-23-2003, 09:19 AM Thread Starter
Ya, the link to the vid doesn't seem to be working. Just reported it to Deej so hopefully it'll be fixed. If anyone wants the vid of it in the meantime, PM me and I'll email it to you. Also have pics of my pivot kit installed as well...
this is it with the plate turned up. You can see the laser cut R6 emblem pretty clearly though..
penfold is offline
post #9 of 20 (permalink) Old 10-23-2003, 10:00 AM
yo pen.the exhaust
BRAVO is offline
post #10 of 20 (permalink) Old 10-23-2003, 10:07 AM
Question--do the leds in this thing work well... can you see them??
jasamb is offline
PRODUCT REVIEW-Clear Alternatives integrated tail light. redneck_r6 Product Reviews 29 07-05-2007 08:24 AM
Clear Alternatives Integrated Tail & Electronic Flasher booser4 Appearance and Exterior Mods 1 12-09-2006 12:53 AM
Trick flasher with Protons + CA Integrated tail? raf_k Appearance and Exterior Mods 1 07-14-2006 08:54 AM
2003 R6 integrated tail light - looking to buy Tommy2003R6 General Discussions 1 05-02-2006 09:15 AM
Integrated tail light problems,please help R6nutter6 General Discussions 5 05-22-2005 04:28 AM
