Winterizing. - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 4 (permalink) Old 10-04-2010, 11:12 AM Thread Starter
Knee drags YOU!
Panici's Avatar
Bike: '05 R6 + Vintage Yamahas
Images: 1
Winterizing.
Hey guys,
Wondering if there is anything special I should do to winterize my bike, now that i'm using it for track riding.
Cooling System
I'm going to drain the Water+Water Wetter that I have in there now.
--Do I need to fill the bike with coolant, or can I just let it sit empty?
Battery
Taking the battery out and putting it on a tender.
Tires
I've got BT-003RS's on there with one track day on them. I plan to put the bike up on front/rear stands and leave it that way all winter.
--Any specific pressures I should have in the tires?
Fuel
Tank is full of 91 and Stabil. Ran the bike for about 10 minutes to get the stabil in the entire fuel system.
Thanks!
Panici
Mods: Armor Bodies Superbike bodywork, Pirelli SBK Pro Slicks, Renthal 50mm Clipons, Bickle warmers, etc, etc...
Gear: ATGATT down to the mouthguard.
A few vintage Yamaha bikes
Panici is offline
post #2 of 4 (permalink) Old 10-04-2010, 12:27 PM
Parts Pimp
ChiefSmokeDawg's Avatar
Bike: 2002 R6, 2008 R6
Re: Winterizing.
There was a thread posted like 4 days ago about this. in that thread you will find a link to a search showing other threads
ChiefSmokeDawg is offline
post #3 of 4 (permalink) Old 10-04-2010, 05:44 PM Thread Starter
Knee drags YOU!
Panici's Avatar
Images: 1
Re: Winterizing.
Right, but my question was more specific in a few areas. Namely tire pressure and running straight water.
Panici is offline
post #4 of 4 (permalink) Old 01-06-2011, 12:13 PM
Motorcycles rock!!
Bike: 2005 Yamaha R6
Re: Winterizing.
If your storage area will never get below freezing for extended periods of time, their should be no need to drain the water+water wetter. However, for insurance, you may want to drain and refill it with the standard 50/50 antifreeze mixture. This just makes more work in the spring because I would drain/refill with distilled water a couple of times just to flush as much antifreeze out as possible.
I would just inflate the tires as you do normally and even add a psi or two and not worry about it.
My winter maintenance has varied for all of the different motorcycles that I have owned, and I have never had a failure due to something specific that I did or did not do.
Sportbikes rock!
R6forum997 is offline
Winterizing yamar605 General Discussions 22 12-21-2009 02:08 PM
Winterizing an R6 YamahaR6228 General Discussions 0 11-24-2007 12:26 PM
Oil change and winterizing Rrwing General Discussions 6 11-15-2007 12:06 AM
Winterizing your R6 YZFRSix General Discussions 15 09-13-2005 05:35 AM
Winterizing tips for my 04 R6... ckmerc General Discussions 16 10-15-2004 04:11 AM
