tech check? - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 7 (permalink) Old 09-30-2011, 02:37 PM Thread Starter
Zable's Avatar
Bike: 03 Yamaha R6
tech check?
what do the techs check on your bikes before they approve it so i know mine is good to go once i take it for the first time?
Zable is offline
post #2 of 7 (permalink) Old 09-30-2011, 02:44 PM
Super Mod
mx3TT's Avatar
Bike: 05 R6
Images: 1
Send a message via AIM to mx3TT
Re: tech check?
Any leaks is the main part. Brake Pads, tire life, anything loose that can fly off, throttle return, and chain slack.
And really you should check it over yourself. You need to know your machine is top notch when you are out there. You dont want to be worrying about old brake pads or tires that might not be up to the job or a small oil leak that can get worse at any time. There are some seriously shitty looking bikes in the paddock, but I can assure you they dont leak and everything is either zip tied or safety wired into place.
RED 2005 R6
Racefit Growler - Solo Exhaust Bracket - Lockhart Phillips No Cut Carbon Fiber Frame Sliders - Lockhart Phillips Carbon Fiber Swingarm Sliders - Puig Tinted Double Bubble Windscreen - Pirelli Diablo DRC - BMC Air Filter - Shift Shaft Support - Dyno Jet Power Commander 3 USB - Yamaha Factory Seat Cowl - Factory Pro +4 Ignition Advancer - Graves Slide Stops - 520 Conversion(-1,+2) AFAM/DIDERV3 - Graves Smog Block Off Plates - Speedo Healer - GPR Steering Damper - Dyno Jet Quick Shifter
mx3TT is offline
post #3 of 7 (permalink) Old 09-30-2011, 02:46 PM
Original Member-Vendor
Agg2001's Avatar
Bike: 2007 R6, 2005 CRF250r
Re: tech check?
tech at a track day, or at an inspection place?
Agg2001 is offline
post #4 of 7 (permalink) Old 09-30-2011, 02:57 PM Thread Starter
Zable's Avatar
Bike: 03 Yamaha R6
Re: tech check?
tech at a track day
Zable is offline
post #5 of 7 (permalink) Old 09-30-2011, 03:00 PM
Agg2001's Avatar
Re: tech check?
our guys check the throttle slack, brake, clutch, sliders (if applicable) for being installed securely, both pegs, shifter lever, rear brake pedal, and chain slack. they also look at your tires. and if you're in street body, they make sure things are taped up correctly, and then do a look-over at your lid to make sure it aint beat to crap.
Agg2001 is offline
post #6 of 7 (permalink) Old 09-30-2011, 03:49 PM
Derp
ramm's Avatar
Bike: 2007 R6
Re: tech check?
All this....
And make sure you have water-wetter or water for coolant.
STT SOUTHERN DIVISION STAFF
ramm is offline
post #7 of 7 (permalink) Old 09-30-2011, 05:06 PM
Meh
Fallis's Avatar
Bike: 05 R6, and other stuff
Re: tech check?
Check the web site for the track day org.
None of the orgs I've run with in the SoCal area have required water-only for coolant.
If you're coming out to Auto Club, here's the stuff I remember Fastrack checking:
All your controls, pegs, sliders, fairings need to be working and well mounted. You need to have good tire tread. You're chain needs to be in good shape and have the proper amount of slack.
All lights, reflectors and wheel weights need to be taped up. Everyone forgets to do the wheel weights.
You need to have a 1 piece or 2 piece suit with full circumference zipper. You need to have a back protector. (Never been checked on the back protector.)
Fallis is offline
check check bitches Blue 08 R6 Test section 10 03-04-2013 01:44 AM
Need some tech help r6ride3r04 General Discussions 3 08-26-2011 04:41 PM
how to check a Check engine light on a 2004 R6 1g jacob General Discussions 1 06-27-2010 03:51 PM
Agv Gp-tech 7 arrrrrgh 6 Gear For Sale 4 01-31-2010 05:23 AM
check check one twooo Xyster Test section 1 09-21-2009 02:40 AM
