Lowside question, front end feel? - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 31 (permalink) Old 11-29-2011, 07:56 PM Thread Starter
So this past weekend I ran chuckwalla ccw and at t-14 I kept getting some weird feedback from my bike. Instead of being able to relax after turn in and let the bike cruise it's course I had to fight the bars to make the turn. The front end felt twitchy, as if it were sliding out a bit, and I would have to physically turn the bars to keep on line. Since I haven't been down yet I can only assume this was a sign that I was about to lowside. Any ideas as to what could be the issue. The rest of the track was fine and I had zero issues.
Basically I'm wondering if the description fits the feel of a bike about to let go? I would like to know in case it does let go I can relax and go with it instead of getting tense and fighting it.
manny is offline
post #2 of 31 (permalink) Old 12-06-2011, 08:16 AM
Parts Pimp
ChiefSmokeDawg's Avatar
Bike: 2002 R6, 2008 R6
Re: Lowside question, front end feel?
Tire pressure? Suspension setup?
ChiefSmokeDawg is offline
post #3 of 31 (permalink) Old 12-06-2011, 09:18 AM Thread Starter
Q2's 30/29. I'm still on factory settings suspension wise. I plan on getting the suspension dialed in over the winter break but if it were the suspension I would think I would have problems with the rest of the track as well.
manny is offline
post #4 of 31 (permalink) Old 12-06-2011, 09:29 AM
Parts Pimp
Maybe you are just really good on that turn and feel it there. I'll let others chime in. I have little faith in those tires. A few people I ride with complained of a similar sensation and in fact did lowside shortly afterwards in that spot.
So it could just be the front end getting ready to let go, but I can't be sure or make an accurate assumption. It's safe to say that not having the suspension setup ever isn't helping any.
Having to continuously provide input to the bars to hold a line is a sign of shitty suspension setup.
post #5 of 31 (permalink) Old 12-06-2011, 11:11 AM
billdozer
WildBill420's Avatar
Bike: 2011 R6
get your suspension setup and tires made for the track. Being prepared makes a huge difference at the track and it can keep you riding all day! the stock suspension setup isn't bad but its not intended for track use and is a bit soft and jumpy. After my first setup it was a noticeable difference in handling and feel.
WildBill420 is offline
post #6 of 31 (permalink) Old 12-06-2011, 11:59 AM Thread Starter
Yeah I need to get the suspension setup but the guy I want to go to basically works out of his personal garage and as such I need to get stands before we can get started. Strange to hear this input about the Q2's as pretty much every review I have read has been positive. They held really well at Willow Springs. Chuck is strange though, instead of beading up rubber on the tires it seemed like I was cleaning my tires up. They almost look like there brand new as the tearing and bald up rubber from my last track day was cleaned off.
manny is offline
post #7 of 31 (permalink) Old 12-06-2011, 12:21 PM
Parts Pimp
That's a GREAT sign!! It means you're smooth getting on the throttle, and your suspension is probably not all that far off in regards to rebound settings
I rode em a couple times and didn't take to them well. I am partial to a softer carcass tire in general.
post #8 of 31 (permalink) Old 12-06-2011, 01:46 PM
Meh
Fallis's Avatar
Bike: 05 R6, and other stuff
The surface at Chuck is only 2 years old, and much different compared to the way old pavement at Willow. That may be a factor in the tires cleaning up. I remember having similar wear the one time I was out there.
I rode Chuck clock-wise, so I don't know what T-14 is CCW, but it may be something as simple as the line your taking. I kept struggling with turn 5 at Big Willow. I kept randomly missing apexes and felt like I was fighting the bike to get it turned. After talking to a control rider I realized I was trying to turn in where the track was off-camber, and hence it took waaay more effort than expected to get the bike turned.
Fallis is offline
post #9 of 31 (permalink) Old 12-06-2011, 01:59 PM
Is this a segment?
imaking20's Avatar
Bike: Vengesicle
Some great feedback. I think the OP has done a pretty good job of narrowing down the situation to help find a resolution. And like has already been mentioned, tire pressure and suspension can have A LOT to do with weird sensations - even isolated ones due to the nature of a particular turn.
Also as Fallis mentioned, it could simply be your approach considering the incident seems isolated to that corner.
I'm a huge fan of the Q2 and have had great luck with it. I had similar front end issues on Pures (the tires weren't a factor, just clarifying) on a turn that crests a hill at the apex - I was pushing a little wide. I adjusted my front ride height a few mm and it made all the difference in the world. My front end was sitting too high in relation to my rear - causing the front to essentially just "lay over" which made it push.
Good luck OP
Rest in Peace - Jason "Snocompton" Jones 2/23/87 - 11/4/11
imaking20 is offline
post #10 of 31 (permalink) Old 12-06-2011, 07:27 PM
1000rrk5's Avatar
The Q2s r plenty good for regular TDs, some of us wont find the limit of those tires. Wat was the temp at the track that day.
1000rrk5 is offline
Cracking noise/feel in front end? begz97 Garage / Mechanical Help 2 07-20-2011 05:05 AM
Lowside... Synx General Discussions 4 10-18-2010 06:02 PM
Do i really need to change my oil after a lowside? exindust General Discussions 6 06-14-2008 12:01 PM
Lowside Genesis General Discussions 6 09-04-2007 07:34 AM
front brakes feel off r-ryder General Discussions 8 04-20-2005 11:53 AM
