Going through the motions - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 84 (permalink) Old 02-03-2012, 11:02 AM Thread Starter
gotthefeelin's Avatar
Bike: Pos
Lets talk about how to's for practical track/riding situations... as if you're running through the game plan in your head before the race.
Coming off the straight into the first turn.
Watching the breaking markers (later the braking=the harder the tip in and faster on the gas)
knees gripping the tank to support your weight
braking and pulling the clutch in and blipping while dropping down 2-3 gears, easing of the clutch lever slowly
easing the hold on the brakes before tipping in
looking through the turn
hard on the gas at the apex.
When im tipping in whats going through my mind regarding BP is - Am i on the balls of feet? am i off the seat? Is my knee driving into the gas tank? Is my other knee out as a feeler? Is my forearm follwing the gas tank and is elbow pit area tucked around the tank? are my wrists relaxed and light on the bars? Am i ONLY looking through the turn?
Whats peoples thoughts on being off the seat when braking for say sharp turns so you're allready setup? Eliminate a movement of braking then sliding off seat...
Where is everyone shifting?
Im wrapping my head around the use of the quickshifter now...
lets get this thing going!!!
gotthefeelin is offline
post #2 of 84 (permalink) Old 02-03-2012, 12:58 PM
pin it to win it
bryan j's Avatar
Bike: 07 r6, 06 yz250f
Re: Going through the motions
i like to be in line while braking hard, or atleast have my upper body in line with the bike. Im ok with having my knee out and ass off the seat while braking tho.
I use the clutch up shifting and down. Pretty decent at blipping, I blip once per gear. I dont do 2-3 at a time
Go fast parts:
, Shorai battery.
Body:
Support the forum Vendors
bryan j is offline
post #3 of 84 (permalink) Old 02-03-2012, 02:09 PM
Team STG Racing
Chaotic's Avatar
Bike: 06 R1,08 R6,09 675,10 R6
I don't brake hard like I used too. I brake lighter...for longer. In other words, i might brake at the same place as other people, but i brake lighter (which opens up passing opportunities) and i stay on the brakes till apex.
Then i get off the brakes and on the gas while dipping my head/upper body to take away lean angle as i straighten the bike up and increase throttle.
Chris Broome
Sportbike Track Time Southern Division/Speed Academy Instructor
WERA Expert #2
Sponsors:
- Bell Helmets - KNOX
Chaotic is offline
post #4 of 84 (permalink) Old 02-03-2012, 02:34 PM
pin it to win it
bryan j's Avatar
that makes a lot of sense, ill have to give that a try
Go fast parts:
, Shorai battery.
Body:
bryan j is offline
post #5 of 84 (permalink) Old 02-03-2012, 03:33 PM
Team STG Racing
Chaotic's Avatar
Be careful with that. It is something you have to work up to. When i say i am still on the brakes at apex, i mean like 1-2%...because im using 95-96% of my available traction for lean angle.
...and leaving myself 2-3% safety zone.
I don't have to tell you what happens when you go over 100%.
Chris Broome
WERA Expert #2
Sponsors:
Chaotic is offline
post #6 of 84 (permalink) Old 02-03-2012, 04:12 PM Thread Starter
Bike: Pos
I lowsided in a turn once cause i was trying to brake late and I think I wasn't off the brake enough when tipping in(I tip in hard naturally and combined with running out of real estate I tipped in even harder) and I tucked the front end.
How does ur method work exactly? Can ya walk me through it?
post #7 of 84 (permalink) Old 02-04-2012, 06:05 AM
Team STG Racing
Chaotic's Avatar
To be honest, I had never trail braked before August of last year. I learned how to trail brake at the Speed Academy. They did drills that teach you exactly how much "1% braking" is and then we did trail braking drills. Had it not been for that instruction, I probably still wouldn't be doing it right.
But to answer your question, I arrive at my braking marker and i already have my butt scooted off the inside of the seat and my leg out and im on the brakes, bracing myself with my outside leg on tank (this isnt a situation where im braking HARD, in those situations, i leave both legs against the tank while im braking HARD, then stick my inside knee out right before i tip in).
As i tip in and start adding lean angle, i start reducing brake pressure in an amount relative to the amount of lean angle im adding so i dont use up all my available traction.
90% braking + 10% available lean angle
80% braking + 20% available lean angle
So on and so forth. Eventually i will arrive at apex with something like 95% lean angle and 1-2% braking. That little bit of braking is enough to alter the geometry and help the bike finish off the turn. Then from there, I start applying throttle.
Let me know if that doesnt answer your question and I will try to explain it better.
Chris Broome
WERA Expert #2
Sponsors:
Chaotic is offline
post #8 of 84 (permalink) Old 02-04-2012, 06:22 AM
derffred's Avatar
Bike: 2007 Candy Red R6
Send a message via AIM to derffred
Great thread
Upgrades List
<- Add me
RIP BallistiK
derffred is offline
post #9 of 84 (permalink) Old 02-04-2012, 07:40 AM
candy red
lopez95632's Avatar
Bike: 07 r6s
Send a message via MSN to lopez95632
Awesome responce chaotic! So how I picture you doing it is something like this
Breaks going in:
Your here
Lean:
Your here
Than as your in the corner it gets to this point
Braking:
Now your here
Lean angle:
Now your here
Than when your coming out of the corner its like this
Breaking:
Your here
Lean angle
Your here
With give or take a little incase you need it.
must read for new members
lopez95632 is offline
post #10 of 84 (permalink) Old 02-04-2012, 07:42 AM
candy red
lopez95632's Avatar
Bike: 07 r6s
Now why the **** doesn't my post look like how I made it!?!??!
The first line should be all the way to the right.
2 and 3 lines should BOTH be in the middle
And line six should be all the way to the right.
I hope it helps.
