Help with superbike tail install - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 11 (permalink) Old 03-07-2012, 08:47 PM Thread Starter
track rookie
tnsouthpaw's Avatar
Bike: 07
I picked up a set of track bodywork and I'm stumped at how to mount the tail section. The bodywork is from a company called iTrackRace, which mainly sells on ebay. Yes, these are cheap plastics compared to AB, Shark, etc, but they seem to be similarly made to Optimals (maybe from same manufacturer in China?).
Regardless, I could use some input from folks that have installed superbike tails. When I fit the tail over the subframe w/o any supports, it fits GREAT!
Here is the tail just sitting on subframe (sorry, phone pic)...
However, I'm 215lbs so I need to use the support pieces. I have two identical mount pieces, but no idea on how to mount them. I assume one goes towards the rear and the other goes near the battery, but no configuration that I have tried has fit well. Here is one of the pieces semi-mounted behind the battery on the subframe, but hell, it might not go there either. I just don't know.
Anyone use this kit or similar that knows how this is supposed to mount? Again, I have two mount pieces that are identical to the one pictured. Oh, and i emailed iTrack twice and have not heard back yet.
Thanks!
insert witty comment here
tnsouthpaw is offline
post #2 of 11 (permalink) Old 03-08-2012, 10:54 AM
I Race Motorcycles
DeFran's Avatar
Re: Help with superbike tail install
Not sure for the R6 but I know for a fact that for gsxrs that piece mounts to the underside of the sbk tail using pop rivets. Find a spot where it would rest on your subframe and conform to the shape of the tail and that should be the mounting point on the tail.
Bart DeFrancesco
2017 CCS Expert Atlantic Champion, Lightweight SBK, SS, Ul SBK, GP, GTL. Overall Expert #2
2013 CCS Expert Atlantic Champion, Lightweight SBK, SS, UL SBK, GTL.
2013 Summit Point track champion, same classes as above.
2012 CCS Expert Lightweight SS NJMP Track Champion.
2007 WERA Northeast Supermoto Champion
2006 WERA Northeast & Mid Atlantic Champion.
C SBK, C SS, B SS
DeFran is offline
post #3 of 11 (permalink) Old 03-08-2012, 11:14 AM
I hate you Turn 4!
aaronk277's Avatar
Bike: 09 Orca
I have the same set but for an 08-09. I used a wing nut and bolt with washers on both sides to attach the u shaped piece to the frame doesn't allow the seat to move up and down and holds it in place really well. I also took the seat foam and shaved it down and placed it uderneath the front of the seat were it meets the tank. Even less movement and then ran acouple piece of duct tape around the edge by the tank so it doesn't rub up against the tank. I'll post up a pic the how I attached the undertail support when I get home tonight around 9
Join the XBL Races on MotoGp 14 here
Join the XBL Races on SBKX here
Chat thread here
600 Superbike Series Novice # 277
aaronk277 is offline
post #4 of 11 (permalink) Old 03-08-2012, 06:16 PM
I hate you Turn 4!
aaronk277's Avatar
Bike: 09 Orca
so here is mine, instead of cutting the undertail bracket I bought a 2in wide 1/8 thick piece of aluminum at HD and drilled 4 holes, 2 for attaching it to the subframe and 2 to attach the seat to the frame.
by
, on Flickr
by
, on Flickr
by
, on Flickr
Chat thread here
post #5 of 11 (permalink) Old 03-08-2012, 07:57 PM Thread Starter
track rookie
tnsouthpaw's Avatar
Bike: 07
thanks all for the replies.
aaron - I appreciate the pics! I like the metal bracket setup. Have you had any issues running it this way? I obviously won't be putting any weight on the tail, other than a gopro, so seems like that should be okay.
As for the provided support piece, I believe I have mine in the same basic spot and direction as yours, but I still have a rather large gap at the tank area. My pop rivets don't hold that well either, so that could be the other issue. I'll copy your bracket setup and your wingnut bolts and see how it goes. Thanks again.
post #6 of 11 (permalink) Old 03-09-2012, 03:19 PM
I hate you Turn 4!
aaronk277's Avatar
Bike: 09 Orca
Those two black looking plates(cann't remember what they are called) clipped over the metal and on the underside have a machine threaded screw that I use to attach the seat directly to. I ended up picking those up at a local fastner shop by where I work, though I think HD has them too not sure though.
As for the gap, I guess I'd had to see a pic to better understand were the concern is. Post up another pic and I'll try to help you out as much as I can.
As far as issues go, None what so ever the seat is down tight and doesn't move at all
Chat thread here
post #7 of 11 (permalink) Old 04-22-2012, 08:43 PM Thread Starter
track rookie
tnsouthpaw's Avatar
Bike: 07
finally got my bodywork mounted. For the tail, instead of mounting the support piece, I ended up just using about 1.5" of foam between the subframe and tail. That's the only way I could get it to mount properly. Seems fairly sturdy, but I'll know for sure at Barber this coming weekend.
Oh, and I sent at least 5 emails to iTrack and never heard back. Definitely wouldn't recommend them for customer service. And part of my upper cracked around the radiator during install, so we'll see how long this set lasts....
post #8 of 11 (permalink) Old 06-26-2014, 01:18 PM
Sammiches
haze748's Avatar
Bike: Red 07 R6
Send a message via AIM to haze748
Thread jack for my own issue. I have an armour bodies SBK tail and am unsure how to mount the seat support piece. I called woodcraft and they said it just floats in there which seems counterintuitive. 2007 and here's a pic:
Help cause I'm dumb.
haze748 is offline
post #9 of 11 (permalink) Old 06-26-2014, 09:27 PM
pin it to win it
bryan j's Avatar
Bike: 07 r6, 06 yz250f
Scoot it forward so the lip rest on the tank bracket. Then it lines up with those holes in the subframe. I just went thru the same deal. Doesn't fit for shit so I took my dremel to it and made it fit.
Go fast parts:
, Shorai battery.
Body:
Support the forum Vendors
bryan j is offline
post #10 of 11 (permalink) Old 06-27-2014, 01:19 AM
Sammiches
haze748's Avatar
Bike: Red 07 R6
I'll give that a whirl tomorrow or the day after. Just seems kinda dumb to have something floating around in there and sitting on top of all the electrical guts.
haze748 is offline
do i need to remove tail fairing to install tail tidy? r6woo General Discussions 5 09-09-2010 07:08 AM
O8 superbike tail on 07 track bike Toe Garage / Mechanical Help 0 08-15-2010 08:56 PM
Catalyst Racing - Superbike Tail Sizerp Appearance and Exterior Mods 7 06-12-2010 10:45 PM
superbike tail seat support help kalibos General Discussions 7 11-30-2009 09:23 PM
where to buy superbike tail foam seat JayK Track Tech & Riding Techniques 12 05-01-2009 03:19 PM
