POP QUIZ #12 - Sliding - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 27 (permalink) Old 03-23-2012, 12:39 PM Thread Starter
Meh
Fallis's Avatar
Bike: 05 R6, and other stuff
Yeah, that's right bitches, I'm bringin' it back! All though I'm changing it around, and asking about a topic I don't know any of the answers to, since I've only got the bike sliding a few times and they were pretty minimal, but I'm hoping it'll drum up some good discussion and I'll learn a lot.
So... sliding around at the track-
What are the different ways the bike can slide on the tires?
How do you recognize that it's happening?
When is it good? When is it bad?
How do you maintain control or recover when it happens? For the front tire? For the rear? For both?
How do the tires themselves effect a slide? Street vs. DOT race vs. slicks? Tire pressure?
Fallis is offline
post #2 of 27 (permalink) Old 03-23-2012, 01:43 PM
Parts Pimp
ChiefSmokeDawg's Avatar
Bike: 2002 R6, 2008 R6
Re: POP QUIZ #12 - Sliding
Good call bro
ChiefSmokeDawg is offline
post #3 of 27 (permalink) Old 03-23-2012, 01:58 PM
Parts Pimp
I'll have a stab at what I think..
You can have pushing as well as sliding.. Pushing would generally be when you are going too fast, and the lateral forces are more than the lean angle and tires can handle. The bike can push wide and keep pushing and pushing until you have slowed enough to let the tires grip fully.
While the pushing out occurs, if you make throttle changes that result in any weight transfer, you will feel the bike act accordingly. So if you let off throttle a bit hoping to slow down sooner, the front will start to push out faster than the rear. The opposite occurs when you engage the throttle after getting nervous of the front moving more than the rear.
Now you can get sliding in two ways, one the gas, or off the brakes. On the gas is an obvious one on what's going on. Generally the cause is too much throttle while holding too much lean. This is usually the case with people who are not taking the best lines thru a turn. When the back walks out excessively and corrective action is required, I find that tipping the bike up barely, while easing off the throttle ever so slightly WHILE getting my ass back over the seat is a good way to not get tossed, and to catch the slide quickly.
Hopefully you feel the bike move before you feel the loss of drive from the back wheel spinning. Generally, I will feel a sensation of the back tire following the front around the turn (on DOT's). If you do get the rear to spin up so much that you lose your drive, hold on, cause that's when the rear shock unloads it's weight, then catches and you highsides.
On street tires, if the tire pressure is a little too high, I will get a floating and gliding feeling from the back in addition to the previously mentioned rear following the front feeling.
If you're hard enough on the drive out and the bike follows the front, you aren't gonna get out much faster than that unless you tip up further and drop your weight down/change BP for more contact patch.
In the previous paragraphs I mention this. For the front, if you're trail braking and you feel the front start to push and then feel a jolting type feeling, then you need to ease off that brake!
The rate that a tire loses it's traction during a drive greatly effects the results of a slide. Take those TD slicks for example, they don't drive out as hard as gummy DOT's. The slide is more abrupt, but not so bad that all drive is lost and the rear unloads. On a street tire with a HARD drive, in that same situation, you may not have this result. More or less, (with the same drive/throttle and lean) you're gonna get that unloading of the shock and the back tire is gonna catch hard...
Gotta leave work, so if none of this makes any sense cause I typed it in a hurry, please be easy on me. I will undoubtedly edit this post a handful of times until I am satisfied with it! DISCLAIMER: I do not claim to be any kind of authoritative figure on this topic.
post #4 of 27 (permalink) Old 03-23-2012, 02:03 PM
Pause..Clarify..Dominate
dubhugger's Avatar
Bike: 03 R6
you WILL "highsides"...I gotst the elbows to prove it
"RIDICULOUSLY LARGE IMAGES"
dubhugger is offline
post #5 of 27 (permalink) Old 03-23-2012, 04:14 PM
iRun
pickpocket293's Avatar
Bike: Wal-mart 12-speed
subbed.
pickpocket293 is offline
post #6 of 27 (permalink) Old 03-23-2012, 05:14 PM
Pastor of Muppets
yuengling910's Avatar
Bike: 09 R6, 07 R6S, 05 WR250F
In for this.
I can't provide much first hand experience, I do know from experience and reading TOTW2 that chopping the throttle is always a bad idea. I agree with chief though that standing the bike up a bit (if possible) to get back onto a larger contact patch helps, while modulating throttle input as necesarry.
Is there any way to revive all those pop quiz threads? I've read a few and there is some seriously good info in them.
yuengling910 is offline
post #7 of 27 (permalink) Old 03-23-2012, 05:21 PM
My R6 eats you.
Dieselboy's Avatar
Bike: 2010 Yamaha M1
Images: 1
Backing it in 1:49
NESBA A | CCS #686
///If you ride like lightning, you’re gonna crash like thunder.
Dieselboy is offline
post #8 of 27 (permalink) Old 03-23-2012, 05:22 PM
iRun
Originally Posted by yuengling910 View Post
In for this.
Google them.
post #9 of 27 (permalink) Old 03-23-2012, 05:23 PM
GET OVER IT
R6BLONDIE's Avatar
Bike: '08 R6
Thats a good question... one that i have been thinking about alot
~ R6BLONDIE ~
That Yamaha...
R6BLONDIE is offline
post #10 of 27 (permalink) Old 03-23-2012, 05:25 PM
iRun
Originally Posted by Dieselboy View Post
Backing it in 1:49
Holy shit, my mind is blown. I thought the dude was gonna crash for sure.
Rear tires feels like sliding. normal? the_1 General Discussions 14 08-30-2010 05:21 PM
Hey there. Here's some pics of me sliding down the track. SlasherMcGee General Discussions 31 09-21-2009 12:00 PM
cornering question (sliding across the seat) icepic General Discussions 10 05-31-2008 10:33 PM
sliding feeling Phoenix R6 Track Tech & Riding Techniques 7 05-08-2007 08:07 PM
Rear keeps sliding out Dash090 Track Tech & Riding Techniques 14 04-17-2006 08:29 PM
