Power pures at track - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 24 (permalink) Old 04-13-2012, 06:05 AM Thread Starter
GET OVER IT
R6BLONDIE's Avatar
Bike: '08 R6
Any suggestions as to what pressure hot and cold I should be running power pures at? At the track with no tire warmers.
Sent from my ADR6300 using Motorcycle.com App
~ R6BLONDIE ~
That Yamaha...
R6BLONDIE is offline
post #2 of 24 (permalink) Old 04-13-2012, 06:36 AM
Parts Pimp
ChiefSmokeDawg's Avatar
Bike: 2002 R6, 2008 R6
Re: Power pures at track
They are ma favorite tires. 29/26 cold. Maybe 28/26 if you're fast and it gets hot out, like around 2 pm tomorrow it will be 70+.
We can start you at 29/26 or maybe 30/27 and work from there based on your feedback. But 28/26 is my ideal setup, but until the front gets hot, it's a little heavy on the steering input, but it's also a sweet indicator of when the front tire is heating up because steering gets much quicker.
You want the lowest pressure possible with still having good control initially. The lower the pressure, the faster the tires warm up and the hotter they get overall.
I have a real good tire pressure gauge and we can sort this out by setting it initally and then checking em RIGHT when you get off the track and adjusting based on feedback from you.
ChiefSmokeDawg is offline
post #3 of 24 (permalink) Old 04-13-2012, 07:06 AM
candy red
lopez95632's Avatar
Bike: 07 r6s
Send a message via MSN to lopez95632
R6blondie huh..... Wait for it....
must read for new members
lopez95632 is offline
post #4 of 24 (permalink) Old 04-13-2012, 11:37 AM
Meh
Fallis's Avatar
Bike: 05 R6, and other stuff
Don't you want to run higher pressures if it's hot, so you don't overheat the tire? Tires continue to make my head hurt.
Fallis is offline
post #5 of 24 (permalink) Old 04-13-2012, 11:40 AM
My94GT's Avatar
in mine remember we started the day at 29\30 then went the 29\26 then last session i went out 28\26 and those bicthes felt perfect
sig by milko
my build thread-
My94GT is offline
post #6 of 24 (permalink) Old 04-13-2012, 11:44 AM
Parts Pimp
That will effect the rate it heats at, but of she goes out and Runs at say 10 AM, it's gonna 55 out. That tire will go from 26 to 28.5 psi or so. Then the next thing u kno, it's 2 pm an the track surface is about 30 degrees hotter. She's gonna come in and say the tire spun on her or that the bumps in the chicane are tossing the rear around. I'll check the psi and it'll be at almost 31 and we will have to let a pound or two out.
Check each time u get off the track for the pressure and you will have been letting a little out here and there all day as you get faster or the track gets hotter.
post #7 of 24 (permalink) Old 04-13-2012, 11:45 AM
Derp
ramm's Avatar
Bike: 2007 R6
Making the switch to these this year...
for later viewing.
STT SOUTHERN DIVISION STAFF
ramm is offline
post #8 of 24 (permalink) Old 04-13-2012, 11:49 AM
Is this a segment?
imaking20's Avatar
Bike: Vengesicle
I definitely agree that the Pures like to run lower pressure - the tires are as light as they are because they're thin (3 plies opposed to typical 5-6)- as a result they can expand quite a bit with higher temps. I started running like 30/29 with them and as soon as we got some warmth I was sliding all over with the rear. I ended up finding ~28/26 to work very well... and we're talking 100+ degrees outside.
Rest in Peace - Jason "Snocompton" Jones 2/23/87 - 11/4/11
imaking20 is offline
post #9 of 24 (permalink) Old 04-13-2012, 11:55 AM
Parts Pimp
The tires are gonna get hot no matter what. They are a street tire. The main objective is to find the right tire pressure that performs the best and maintain it.
If the tires overheat and get greasy on you, you need Different tires. Cause when you run into that scenario, adding more pressure is gonna further degrade the traction of the tire and it'll have less contact patch and just float on u
post #10 of 24 (permalink) Old 04-13-2012, 11:56 AM
Parts Pimp
Exactly.
Michelin Pures Front&Rear NewBeeR6 Bike Parts For Sale 34 05-30-2012 09:07 AM
Michelin Power Pures are AWSOME!! NewBeeR6 Tire Tech Talk 79 04-13-2012 12:39 PM
Pilot pures $250 a set 08slvr Tire Tech Talk 45 04-06-2012 02:35 PM
Pures .... BallistiK Tire Tech Talk 39 08-12-2011 06:13 PM
Best deal on Pilot pures cuban3jumper General Discussions 7 02-26-2010 12:31 PM
