06 superbike tail install question? - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 7 (permalink) Old 09-03-2012, 01:59 PM Thread Starter
gotthefeelin's Avatar
Bike: Pos
Where do you mount the support piece? Also where are you drilling the holes to support the upper?
Pics would be helpful.
FYI I'm running a woodcraft tail.
gotthefeelin is offline
post #2 of 7 (permalink) Old 09-04-2012, 10:35 AM
Mr. Azim's Avatar
Re: 06 superbike tail install question?
I used the 4 gromet holes/spaces that are located under the seat (where the stock tail mounted to).
Then just 4 holes on each side to hold the under-tail...... I also drilled 4 holes in the centre of the under and zip tied it to the subframe. Makes it a little more secure (no bouncy bouncy).
Novice #84
2006 Yamaha YZF-R6
2013 Sponsors/Supporters
Custom Leather & Vinyl
Lightweight Brake Rotors, Levers & Guards
Racer Training & Motorcycle Accessories/Parts/Repairs
Motorcycle Parts & Accessories
Mr. Azim is offline
post #3 of 7 (permalink) Old 09-04-2012, 10:45 AM Thread Starter
Bike: Pos
Got any pics?
I currently have a woodcraft SS tail thats mounted on the bike but wanted the higher seat from the SB Tail.
Plus it looks cooler.
post #4 of 7 (permalink) Old 09-04-2012, 12:50 PM
vic06's Avatar
You need to enlarge the holes where the support lines up with the frame. I believe the frame holes are 4 mm wide and you have to make them 6 mm.
For the undertail, I used the same two stock holes on the suspension end of the piece where the stock one is attached with push-in screws. Then I drilled four holes for Dzus fasteners.
The top tail piece sat too high on my bike and there's a gap between the top and the bottom halves under the seat. It was the only way to make the screw holes line up. It's not a issue riding and I just tape it over.
ID:	83678   Click image for larger version
MOTORCYCLING. If a Harley is catching up, you're doing it wrong.
09 Yamaha R6 - track only
06 Honda 599
vic06 is offline
post #5 of 7 (permalink) Old 09-04-2012, 02:22 PM
I have 2 belly buttons.
shad0ws's Avatar
Bike: '09 R6
I had the same problem with the top and bottom tail section on my super sport kit. Made the mistake of drilling the holes for the push pins first and then realized it needed to come towards the shock like an 1/8". I just put some masking tape over the panel and trimmed it back until it fit nice and flush with the upper tail section. The push pin holes ended up not lining up after i got it all straight. So I just left them out. The tail is super sturdy without them but I do have 6 dzus fasteners on my tail. If needed. I'll take pic tomorrow and post them. I'm at work right now and won't get off till 6am.
shad0ws is offline
post #6 of 7 (permalink) Old 09-13-2012, 02:47 PM Thread Starter
Bike: Pos
Sb tail mounted. Damn its uncomfortable but I know the benefits will show on the track.
post #7 of 7 (permalink) Old 09-14-2012, 07:35 PM
maddagascar's Avatar
superbike tail is legit. i can feel a lot of things and it makes you actually get off your ass and be on the balls of your feet.
i mounted mine same place as Azim, right where the stock seat used to go.
2013 Sponsors:
, Geared Up Moto,
Build Thread:
maddagascar is offline
Help with superbike tail install tnsouthpaw Track Tech & Riding Techniques 10 06-27-2014 01:22 AM
NEW Sharkskinz Superbike Tail triplestrong Bike Parts For Sale 3 03-10-2012 07:38 AM
do i need to remove tail fairing to install tail tidy? r6woo General Discussions 5 09-09-2010 07:08 AM
Catalyst Racing - Superbike Tail Sizerp Appearance and Exterior Mods 7 06-12-2010 10:45 PM
superbike tail seat support help kalibos General Discussions 7 11-30-2009 09:23 PM
