False Neutral??? Bent shift fork???? - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 12 (permalink) Old 06-25-2013, 05:16 PM Thread Starter
Old Raven's Avatar
Bike: 2005 R6
I began having this issue with my 2005 R6 while at the track last Saturday and Sunday. It seems to happen only when I'm downshifting at very high speeds/RPMs under hard braking from 6th to 5th. The symptom is that I down shift and let the clutch out but the transmission doesn't catch and the bike rolls freely while making a loud "Clacking" noise until I pull the clutch in and shift again.
It's quite scary considering that it usually happens when I'm going over 100mph and trying to quickly downshift for a turn
. Oddly enough it doesn't seem to happen at lower RPM's or if I consciously match rev while shifting. Has anyone ever experienced this?
Old Raven is offline
post #2 of 12 (permalink) Old 06-25-2013, 05:27 PM
Lifetime Premium
mgossel's Avatar
Re: False Neutral??? Bent shift fork????
Yes and I didn't like it
I assumed I hit the shifter before completing the clutch engagement.
mgossel is offline
post #3 of 12 (permalink) Old 06-25-2013, 05:30 PM
Meh
Fallis's Avatar
Bike: 05 R6, and other stuff
It kind of sounds like it's just a bad shift and you're catching a false neutral. Kind of hard to tell without being on the bike to feel it. 6th to 5th is usually a really easy shift to make though.
I'd start with the simple stuff first, and check the clutch cable, lever, arm (down at the clutch cover) and make sure everything is seated right, correct cable slack, cable isn't binding, etc. Basically all the easy stuff to ensure when you're pulling the lever, the clutch is actually disengaging.
If there's transmission problems it usually shows up in 2nd gear. I've never had problems myself, or had a transmission apart, so hopefully some more experienced guys chime in.
Fallis is offline
post #4 of 12 (permalink) Old 06-25-2013, 05:57 PM
When in doubtThrottle out
mercenary's Avatar
Bike: Zuma
False Neutrals happen at the track especially if you are doing any type of endurance. You get lazy shifts and false neutrals. Just pull the clutch, up shift, and slowly feed the clutch back out and you'll be fine even if already tipped into the corner.
Sold: 2009 YZF-R6
Given to the ex-bitch, I mean wife: 2010 Ninja 250
MCRA/CCS#81
Originally Posted by doctorv
I was wrong.
Quote taken 7-16-15 @ 0640CDT
mercenary is offline
post #5 of 12 (permalink) Old 06-26-2013, 09:03 AM Thread Starter
Old Raven's Avatar
Bike: 2005 R6
Thanks for the suggestions Fallis, I plan to go through all of that later this week during my post track day maintenance routine. It very well could have just been a lazy/bad down shift as both times it happend it was late in the session and I was begining to get fatigued.
Mercenary, I wil give that try if it happens again. I'm curious, since you're already rolling and the RPM's have dropped the upshift won't lock up the rear tire and potentially cause a problem if leaned over?
Thanks to both of you for the replies!!!
post #6 of 12 (permalink) Old 06-26-2013, 07:53 PM
Meh
Fallis's Avatar
Nah - that's exactly why you want to shift to a higher gear when you get a false neutral. Worst case, you'd bog the motor a little - but going up a gear is never going to lock the rear tire, or over rev the motor.
Fallis is offline
post #7 of 12 (permalink) Old 06-26-2013, 10:16 PM
"The Dude abides .. "
MELK-MAN's Avatar
so true. If ya happen to catch a false neutral, be sure to upshift. Downshifting could result in a highside, or at the least, is more upsetting to the bike than finding yourself in too low an rpm range.
OP: is your bike set up for GP shift pattern ? i have found standard shifting to be less prone to false neutrals. There are benefits to gp shift, but i will trade not getting false neutrals for a very minor benefit on upshifts. personal preferance.
MELK-MAN is offline
post #8 of 12 (permalink) Old 07-15-2013, 09:01 AM
Lifetime Premium
Gurk's Avatar
Bike: 07R6, 16RSV4
You're letting the clutch out too quickly. False Neutral to me is when you're actually in neutral. Not when it's clacking like that in and out of the gear.
When you pull the clutch all the way in, shift, and let it go too fast, you get rear slide
When you pull the clutch halfway, shift, and let it go too fast, you get that clacking and in and out of gear
When you pull the clutch halfway, shift, and let go smoothly (not too slow, not too fast) you get a perfectly smooth shift like you're supposed to.
Believe me I've done all of those. Star School / Jason Pridmore finally pointed me in the right direction.
Gurk is offline
post #9 of 12 (permalink) Old 07-15-2013, 09:13 AM
MELK-MAN's Avatar
"real" neutral or "false" neutral, clacking or not clacking.. if it's not in gear, it doesn't matter. You have zero engine braking and you are likely going off track if you don't do something in a hurry.
I do agree that there should be some fluidness to letting the clutch out, and that you do not have to pull the clutch all the way in to make shifts..
MELK-MAN is offline
post #10 of 12 (permalink) Old 07-15-2013, 09:32 AM
Lifetime Premium
Gurk's Avatar
Bike: 07R6, 16RSV4
no point arguing the label.
but yeah i can swear by it. it's 100% rider error. after i learned why it happened i was able to correct it. also i'm able to replicate the problem every time.
hopefully helps the OP.
Gurk is offline
false neutral drake18 Garage / Mechanical Help 4 11-07-2011 08:06 AM
crash from a false neutral cdsuperstar General Discussions 12 05-09-2009 05:18 AM
"false neutral" Cjanik Track Tech & Riding Techniques 2 06-04-2008 02:31 PM
False Neutral. straitwangin General Discussions 13 08-09-2007 08:01 PM
Hitting false neutral - too many times... Ragnarok Garage / Mechanical Help 2 07-17-2006 04:05 AM
