What are the differances in the 3rd gens??? - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 17 (permalink) Old 08-31-2013, 12:07 PM Thread Starter
1s1ks1x's Avatar
What Fellas!
I've decided that to come back to track riding and racing that I want a newer bike and may do another build to a 2nd gen later on to use the stuff I have and run a modern vintage class with it.
Correct me if I'm wrong but from bikes I've see at the track and from reading things here and there the 08+ 6's are better and faster then the 06-07. Just wanted to know why. I see more 06-07's fs cheaper but if its that much better then I'll want to spend more to get the 08.
I've ridden an 06 and it may have been the bike but it felt worlds differant then my 03 I didnt like it at all. It was faster down the straights but my bike felt way better in the corners. This was only for 8 laps back to back I ran half of an endurance on the 06 then swaped and ran the rest on mine.
Some of this I think was the 06 not being set up very good.
Some of you transition from the 2nd to 3rd + and what did you guy notice?
Thanks guys!!
1s1ks1x is offline
post #2 of 17 (permalink) Old 08-31-2013, 02:36 PM
your gunna love my nuts!
Ropeymagnumman's Avatar
Bike: 08 R6
Re: What are the differances in the 3rd gens???
08 they made a bunch of changes to the engines internals from 06/07. R6 got a little more restricted after 08 and re-mapped i believe. I could definitely be wrong. Im guessing you would have to be a pretty good rider to tell the differences. If your gonna build a track bike with custom maps and tuning i dont think it matters. If you want the most potent stock bike its gonna be 05 or 08.
Ropeymagnumman is offline
post #3 of 17 (permalink) Old 09-03-2013, 06:12 PM
Meh
Fallis's Avatar
Bike: 05 R6, and other stuff
'08+ later has variable intake length. There's a servo that changes the position of the velocity stacks based on RPM so you get the best of both worlds for low-end torque and high-end horsepower.
'08+ later has longer fork tubes, so you can potentially make the bike sit taller in the front. The 06/07 is known for being a bit twitchy.
Throttle is also restricted in the ECU to 80%, even when you go to the stops. Getting a flash will fix this. Not sure which year this went into effect.
Fallis is offline
post #4 of 17 (permalink) Old 09-03-2013, 09:14 PM
A.Carey_6's Avatar
Bike: 07 R6 Blue
That Is correct. But the 06/07 also have the exup servo. And I think the throttle went into restriction in 06
CVMA #691
A.Carey_6 is offline
post #5 of 17 (permalink) Old 09-10-2013, 10:54 PM
TwistedRoads's Avatar
Bike: 2012 Black/White R6
I know it has to do with emissions but what are the main/specific differences between a California and non California R6 08+?
TwistedRoads is offline
post #6 of 17 (permalink) Old 09-11-2013, 10:48 AM
Meh
Fallis's Avatar
I think the only difference, as on basically every motorcycle, is that the CA models have the charcoal canister thing.
Fallis is offline
post #7 of 17 (permalink) Old 09-11-2013, 04:09 PM Thread Starter
1s1ks1x's Avatar
What kind of rwhp numbers are we looking at? Considerably more then an 03?
1s1ks1x is offline
post #8 of 17 (permalink) Old 09-11-2013, 04:21 PM
"The Dude abides .. "
MELK-MAN's Avatar
a CA throttle body has 2 vacuum hoses that are connected to the front. i have no idea what they do, but i got a used set on Ebay and had to cap them off (no issues once capped) I have got 2 used sets since then and other bikes, and never saw those again.
Not sure if there are other things with the CA bikes or not.
MELK-MAN is offline
post #9 of 17 (permalink) Old 09-11-2013, 04:24 PM
MELK-MAN's Avatar
yup. All that, and the lower triple clamp is higher on the fork tubes for the 08+ for more fork flex (more front end feel), as well the frame has a support that runs from side to side under the airbox on the 06-07 (not there on the 08+ again for more flex/feel).
there were some minor engine refinements in 08+ too, going from 12.7:1 pistons to 13:1 (or thereabouts). Wider crank journals too.
MELK-MAN is offline
post #10 of 17 (permalink) Old 09-11-2013, 10:17 PM
Op, this maybe old news to you since you've been on this forum longer then me but the 08 was the quickest followed by the 09. For some reason Yamaha re mapped the 10+ to be a bit slower. I'm going to guess somthing to do with emissions. I'm sure others could better explain this if its new to you.
Thanks for the info fellas, been searching the forum and goolge about the differences since I managed to get a non cali model in socal lol. No real luck in my search. Figured this was the proper thread to ask said question.
Do your 3rd gens do this? mikeyp03 General Discussions 44 09-12-2012 07:19 PM
2nd,3rd gen rectifiers work on 1st gens? nelsnm352 General Discussions 0 05-02-2012 09:51 AM
For all you first gens out there... R6TRAILER General Discussions 12 12-22-2010 07:26 PM
Let's see those 2nd gens collins Appearance and Exterior Mods 68 02-28-2010 09:14 PM
performance differances between r6 and r6s jwfrml General Discussions 11 05-20-2008 04:49 PM
