Switching from 180/55 to 180/60 - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 38 (permalink) Old 04-23-2014, 11:48 AM Thread Starter
Meh
Fallis's Avatar
Bike: 05 R6, and other stuff
I'm currently running a Super Corsa 180/55 and want to try out the 180/60 next time I need a rear.
I'm due for chain & sprockets and I'll be swapping them out before I need a new tire so I want to make sure I'm setup to throw the 60 series on there without having to mess with chain length at the track.
Is it possible to figure out if I need another link before I've got the tire mounted up? My current setup has me near the middle of adjustment (4 big ticks + 1 little tick on the adjuster). Should that leave enough room for the taller tire? Or should I use one more link when I put the new chain on?
I've never done chain/sprockets myself, so maybe it's way less work than I'm thinking to add a link at the track?
Fallis is offline
post #2 of 38 (permalink) Old 04-23-2014, 02:09 PM
Rubber side down
DarkravenR6's Avatar
Bike: 2006 R6 Raven
Won't be a difference. Sprocket changes affect that but not tires.
2006 Yamaha R6 Raven
DarkravenR6 is offline
post #3 of 38 (permalink) Old 04-23-2014, 02:33 PM Thread Starter
Meh
Fallis's Avatar
Re: Switching from 180/55 to 180/60
Runner a taller tire can definitely effect needed chain length. Typically running a GPA 190/60 you need to add a chain link to avoid having the tire rub on the swing arm and still have the appropriate slack.
Fallis is offline
post #4 of 38 (permalink) Old 04-23-2014, 03:01 PM
Mr. HER6
HIS OWN 6's Avatar
Bike: 08 R6, 15 Ninja300
I've never bought a chain that didn't need to be cut down. I don't bother counting links. Just get it sitting on the sprockets so it fits right and cut off the excess. Plus if you count wrong and need to add a link you better have an extra master in your toolbox.
HIS OWN 6 is offline
post #5 of 38 (permalink) Old 04-23-2014, 03:05 PM
Rubber side down
Bike: 2006 R6 Raven
I stand corrected!
post #6 of 38 (permalink) Old 04-23-2014, 03:07 PM
Mr. HER6
HIS OWN 6's Avatar
I just re-read and see your dilemma. If you cut off a link you'll need a new master link, but if you need to add one you'll need 2 new links. So err on the longer side, but remember that the new chain will stretch a little bit at first and you still want to have some room left for adjustment after that.
post #7 of 38 (permalink) Old 04-23-2014, 03:36 PM Thread Starter
Meh
Fallis's Avatar
I stand corrected!
Mark, are you running the 60 series? Did you need to mess with the chain at all if so?
Fallis is offline
post #8 of 38 (permalink) Old 04-23-2014, 04:02 PM
Mr. HER6
HIS OWN 6's Avatar
No, I'm on the 55. How much swingarm clearance do you have?
post #9 of 38 (permalink) Old 04-23-2014, 04:03 PM
candy red
lopez95632's Avatar
Bike: 07 r6s
Send a message via MSN to lopez95632
My buddy is running the 180/60. Let me see how many links he has on there
must read for new members
lopez95632 is offline
post #10 of 38 (permalink) Old 04-23-2014, 04:22 PM
Reads the rulez
High Side's Avatar
Bike: Turbo'd Ruckus
This is my 2 cents:
If you want to stick with the OEM range of gearing, get a 15/42 set up. I know, I know - that's the same as stock gearing. Here's why:
The 180/60's fit fine with the OEM gearing. I know this because I've ran it for awhile. HOWEVER, the tire tread-swingarm clearance is extremely close. Enough that my tire warmers rub while putting the tire warmers on. I've tried ChickenHawk Pro-lines, Woodcraft's, and my new Capit tire warmers. All rub.
Obviously, the 15/42 sprockets are smaller than the stock 16/45. Using the same number of chain links, your rear axle will get pushed back.
I HAVE NOT tried my tire warmer yet. I might get a chance to try it out tonight. I'll try to update (With pics) as soon as I can.
Oh...yeah...by the way.
My Sharkskinz doesn't work with the kickstand. So, I said eff it, and just removed the entire bracket/everything. Rear stand only from here on out. If you haven't sent your shit off to get painted yet, I would DEFINITELY trim that corner out so it'll clear. Your painter guy can clean it up so it'll look factory. Unfortunately, I had my shit already painted/drilled. I'm not about to hack into my brand new paint job. Now, a crash or two later in the future, yeah, my give a shits will probably be less. But until then...
EDIT: Oh yeah. You can't just add a link to the chain, since technically you have to add 2 links. And if you want to use 16/45 gearing, you CAN NOT add a link to the chain. The chain will be too long and you'll run out of axle adjustment. Been there, done that - that's why I went 15/42.
Originally Posted by bburgess05 View Post
I was going to continue to trash you rookie clowns but it's not even worth it. You're going to spend the rest of your days wasting away and possibility of aquiring talent because you're too ignorant and stubborn to realize you suck... but could be good. You all just keep proving my points.
NESBA "A"
WERA Expert
High Side is offline
180/55 vs 180/60 Supercorsa SwampDog Tire Tech Talk 75 03-28-2014 08:08 AM
Q3 120/70 180/55 diz Bike Parts For Sale 5 10-15-2013 11:54 AM
switching from a 180/55 to a 190/55 - what changes do i need to make? Agg2001 Tire Tech Talk 34 01-20-2012 10:29 AM
180/55 vs. 190/50???? midday88 Tire Tech Talk 21 10-28-2008 07:15 PM
HOW TO do a 180 fastlikeacat How To's... 15 08-03-2007 06:35 PM
