As a new rider, what to work on? - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 14 (permalink) Old 05-23-2014, 08:40 AM Thread Starter
Been riding for a year or so now, track days for me are still a few months away.. Got some canyons near me, and I use the pace to practice but i've found that I constantly keep shifting my focus on different things. What should I focus on in order or importance?
My toes are perched like a bird, i sit a few inches back, i'm short tho at 5"6 so not too far. I flex my core to hold my upper body up and arms loose, holding the bars like a baby bird.
When coming to a corner, I stay on the outside and look into the turn for the apex while either braking or rolling off. I scoot my butt off a small amount, like half a cheek and lower my chest and head to the inside mirror. At about the same time I lower my upper body, I try to consciously make a forceful, but smooth input pushing inside and pulling outside, and look thru the turn. Am I supposed to look at the road as its appearing, or past the road, like through the "wall"? Once leaned and on my line I crack the throttle open, and roll it on slow, or hold it neutral depending on if i'm comfortable with my entry speed. After apex I try to do a nice smooth roll on while standing the bike up. Obviously not wide open, but I pinch it a little every now and then. Anyway, all this is really quick to me still, and I don't always get my mind to practice them every corner. Usually I focus on one thing at a time, like looking thru turn, or throttle inputs. What should I be working on as I go through corners? or maybe I should be working on my line building?
Haunts is offline
post #2 of 14 (permalink) Old 05-23-2014, 10:56 AM
Why yes I don't!!!!!!!!!!
TurboBlew's Avatar
Bike: 2007 In Heaven
Re: As a new rider, what to work on?
Foot/leg position and keeping your arms bent.
Its hard to not sit in the middle of the seat on a streetbike ride because the track is the complete opposite. But you can practice setting your leg position to negotiate a turn so by the time you get on track it will be muscle memory.
TurboBlew is offline
post #3 of 14 (permalink) Old 05-23-2014, 11:17 AM
Hey...watch this
FZ1guy's Avatar
Bike: FZ1; R6; GL1800; SV650
Something that too many of us forget to practice is breaking. This is not something you want to learn how to do with a car turning left in front of you. I believe it was Keith Code that said 'If you ride 100MPH you need to know how to stop from 100MPH'.
Practice panic stops often.
FZ1guy is offline
post #4 of 14 (permalink) Old 05-23-2014, 01:56 PM Thread Starter
I sit my junk about 3 inches from the tank. Can't wait to get some stompgrip or something.. hard af to stop from sliding during braking.
What I do is flap my arms every so often just to make sure my arms are loose.
By setting leg position, do you mean hooking my outside thigh into the tank?
I definitely need to practice this more. What I consciously do now is slowly grab the front brake and by slowly I mean pulling firmly until the front end compresses and then pull harder. Takes about 1 second to do.. sound about right?
Haunts is offline
post #5 of 14 (permalink) Old 05-27-2014, 06:10 PM
Meh
Fallis's Avatar
Bike: 05 R6, and other stuff
Don't forget to be smooth releasing the brakes as well.
Fallis is offline
post #6 of 14 (permalink) Old 05-27-2014, 06:24 PM
Make good choices.
thedub's Avatar
Bike: R6, SV, KTM300, Tiger 800
It's important to take breaks.
AFM #77
Thanks for the support in 2017
thedub is offline
post #7 of 14 (permalink) Old 05-28-2014, 05:19 AM
TurboBlew's Avatar
break me off a piece of that...
post #8 of 14 (permalink) Old 05-28-2014, 05:39 AM
Reads the rulez
High Side's Avatar
Bike: Turbo'd Ruckus
Pee breaks?
Originally Posted by bburgess05 View Post
I was going to continue to trash you rookie clowns but it's not even worth it. You're going to spend the rest of your days wasting away and possibility of aquiring talent because you're too ignorant and stubborn to realize you suck... but could be good. You all just keep proving my points.
NESBA "A"
WERA Expert
High Side is offline
post #9 of 14 (permalink) Old 05-28-2014, 07:44 AM
Sherman Connoisseur
m3lover1's Avatar
Bike: Two dirty dirty bikes
I gave some advice in this thread you might want to check out. Too lazy to rewrite everything. I'm not so sure how helpful it would be since you are new, but check it out and if it helps, awesome!
I <3 PASSION MOTORSPORTS
Ive taken bigger shits than Ricky, but he has personality, so that should count for something......right?
I see my balls are in high demand in terms of cupping
RIP Jason (Snocompton). We will miss you.
m3lover1 is offline
post #10 of 14 (permalink) Old 05-28-2014, 09:11 AM Thread Starter
I find myself occasionally holding on to the front brake going into some corners.. solid braking upright and then releasing to maybe about 5-10% braking and then leaning.. but I found some articles on trail braking and they mention tapering off AS you add lean angle. Is there a right and wrong way? or maybe one is better suited for the track?
Awesome.. thank you ima go thru this thread and take notes!
Haunts is offline
Michigan Rider's & Windsor Canada Rider list ShadowBurn North Central 323 03-09-2016 08:24 AM
New rider from Houston TX!! Prob the youngest rider here too... Yamaha2218 New Member Section 10 01-13-2010 09:28 AM
Present R1 rider, future R6 rider j334 New Member Section 1 06-24-2007 08:54 PM
could it work? ronny123 Appearance and Exterior Mods 0 06-12-2007 04:02 PM
Rider-to-rider communicators... you guys used any? SolaceRye General Discussions 31 10-27-2003 04:06 PM
