Increasing rear from 45T to 46T - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 7 (permalink) Old 06-18-2014, 03:52 PM Thread Starter
Dezmonster's Avatar
Hi R6 brainstrust
Q:1
I have a spare rear sprocket up one tooth from
(what I think is) OEM for my '06 R6 16- 45
I am after a little more punch out of the corners , I spend a lot of time on
a reduced short circuit track up
here in Oz with lots of tight corners.
Would one tooth make any noticeable difference or should I just stop drinking
beer and loose 5 kilo's
Q:2
Running Supercorsa SP 180 55
Considering Supercorsa SP 190 60 for next rear do I HAVE to change rear shock spacers or can I just instal and ride , I would like the bike to be a little quicker in direction change.
Cheers
Dezmonster is offline
post #2 of 7 (permalink) Old 06-18-2014, 05:43 PM
racefreak's Avatar
Bike: Yamaha R6
Re: Increasing rear from 45T to 46T
If you have the 46 tooth go ahead and use it! It will help, but you probably won't notice much of a difference. If you went down a tooth in the front there would be a noticeable difference. Every track is different, but if it's a tight track you definitely want to shorten up the gearing. It all depends on what you're after. If you want excellent lap times, you want to get the tightest gearing you can without topping out 6th gear before the end of the straight.
As for the tire, I wouldn't be so sure pirelli 180/60 will have better turn in than the 180/55. I don't know, I'm just saying because pirell's 180/60 is comaprable to other tire manufacturers 190/55. It says 180, but it's actually wider. I remember looking at the spec sheet for it a while ago. Anyway, I'm sure it would have better edge grip, so can't hurt. But the flipside of that is with the taller tire, your gearing will be taller again, so with your 46 tooth rear sprocket you'd probably be at a wash in terms of gearing. But for sure use the 46 tooth rear sprocket if you have it.
WMRRA #95
racefreak is offline
post #3 of 7 (permalink) Old 06-18-2014, 06:40 PM
Why yes I don't!!!!!!!!!!
TurboBlew's Avatar
Bike: 2007 In Heaven
How much room do you have in the axle adjuster? Its going to shorten wheelbase but if you use a 60 aspect tire it might rub the bodywork or swingarm.
Like mentioned above... a 15 tooth front will have a more dramatic effect.
TurboBlew is offline
post #4 of 7 (permalink) Old 06-20-2014, 08:18 AM
Schwizard's Avatar
Bike: 2008 R6 Race
Take a look in the paddock at what the fast guys are running for gearing. I can almost bet its stock, if not slightly taller. Why is this? Because the fast guys are carrying a lot of corner speed and the taller gearing helps maintain that through the corners. But, it does depend what track you're at too.
My first couple years racing, I ran super short gearing and my times were sub par at best. When I went back to stock gearing and extended the wheel base, I started coming into the turns faster, and carrying more speed, and my times dropped significantly. It was beautiful how such a small adjustment made a huge difference.
Give it a try though! I think you'll quickly find out what you like and what you don't.
If you want the perfect setup, you'll probably have to adjust ride height. But if you want quicker turn in, slapping on a 190 will do that. It's a taller tire, so it will make your turn in a bit faster, as your geometry is more ass up and nose down.
-Jes CRA #426E
Bell Helmets, AXO, Leatt, Dunlop
Schwizard is offline
post #5 of 7 (permalink) Old 07-05-2014, 05:57 AM
WTF?
moto1320's Avatar
Bike: '06 R6
One tooth up overall is the ticket. I run -1/-2 to get there though. You can slap that 46 you have on to see how you like the ratio. If you do, when it comes time to replace the chain and sprockets I would convert to -1/-2. The slight increase in wheel base and decreased leverage on the swing arm with the smaller gear set gives the R6 some needed stability. Everyone will have a different opinion on this though.
My bike came with -1/+2 and I absolutely hated it on the track. I'm lucky enough to have a top AMA crew chief as my track day provider and deferred to him. If he can put an R6 on the top step, I do what he says... There is one course where I may try -1/-1 and play with going longer than stock, but overall I love the bike just one tooth up.
moto1320 is offline
post #6 of 7 (permalink) Old 07-05-2014, 06:46 AM
Reads the rulez
High Side's Avatar
Bike: Turbo'd Ruckus
I still don't know why people make massive changes from the OEM gearing for most road racing tracks in the US.
Originally Posted by bburgess05 View Post
I was going to continue to trash you rookie clowns but it's not even worth it. You're going to spend the rest of your days wasting away and possibility of aquiring talent because you're too ignorant and stubborn to realize you suck... but could be good. You all just keep proving my points.
NESBA "A"
WERA Expert
High Side is offline
post #7 of 7 (permalink) Old 07-07-2014, 02:16 PM
Post count is gay........
APO2112's Avatar
Bike: 2006 R6 636cc SBK
15/43 gearing, 190/55 tire combo are pretty near the stock sprockets/rear tire setup. I love this combo, but I'm not fast enough yet to fully realize the potential.
"I can't believe that God put us on this earth to be ordinary." Lou Holtz
“The basic difference between an ordinary man and a warrior is that a warrior takes everything as a challenge while an ordinary man takes everything as a blessing or a curse.” Carlos Castaneda
APO2112 is offline
Vortex 520 46T Rear Sprocket for 2006-13 R6- Like New mikdivad Bike Parts For Sale 6 04-13-2013 09:29 PM
Vortex 45T 520 CAT5 Rear Sprocket for 06-12 R6 mikdivad Bike Parts For Sale 4 09-19-2012 06:59 AM
Vortex 45T 520 Rear Sprocket mikdivad Bike Parts For Sale 4 06-12-2012 08:04 AM
2 X R6 NEW Afam 520 Rear sprockets 46t and 47t for $50 each Motomadman Bike Parts For Sale 5 04-10-2012 09:00 PM
stealth candy red rear 46t sprocket s10lolo Bike Parts For Sale 7 08-22-2009 07:48 PM
