PC Quick Shifter - Part #s - ADVICE PLEASE - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 4 (permalink) Old 12-03-2014, 09:39 PM Thread Starter
My R6 eats my money.
Pharaoh6's Avatar
Bike: '09 R6
I've been meaning to do this mod for a while, getting around to it now.
Just confirming....are these the part numbers I need for the Power Commander quick shift setup? Are all these parts needed? In addition, have any thoughts on these parts and the quality? I have a PCV. Not running GP shift. Thanks much
Qem-15 -- Expansion Module
4-113 -- Pressure Sensor (pull)
32104060 -- Shift Rod A
32105030 -- Shift Rod D
'09 - Carbon/matte-white wrap, BAUCE Racing ECU Flash, Dyno tuned (each cylinder), Brembo 19x18 Master Cylinder, Pazzo clutch/brembo replacement levers, AGGs tygon reservoir tubing front/rear, Woodcraft Clip-ons/Renthal Grips, Motion Pro Throttle Kit, EBC Front/Rear Contour XC Rotors, Front/Rear Galfer lines, Bohemian Rearsets, Scotts Damper, Arrow Race headers, Akrapovic titanium slip-on/ CF heat shields, PCV, K&N air filter, Supersprox-Stealth Sprockets(-1/+1), EK MVXZ 520 Chain, Healtech Glpro-X, Michelin Power Cups, AGG block-offs, AIS/CharcoalCan/Exup-Servo DELETE, Puig screen, GB Racing Case Covers(Ignition, Stator, Clutch), JPR Performance keyless gas cap, XT-Racing Mini Lap, Shorai battery, Greggs flushmounts, Stomp grips, Smoke hotbodies tail, Targa rear seat cowl, Graves brake return spring, HT Moto seat covers, BiXenon Projector Kit, Engine Ice, Motul 300v, Sliders, Leo Vince Dion Device.
Gear: AGV Pista GP, Arlen Ness Kangaroo suit/GP Gloves, AS Super Techs
Build Thread: Akrapovic Undertail...to Dual R1 Undertail
Pharaoh6 is offline
post #2 of 4 (permalink) Old 12-05-2014, 08:30 AM Thread Starter
Pharaoh6's Avatar
Bike: '09 R6
Re: PC Quick Shifter - Part #s - ADVICE PLEASE
bump
Pharaoh6 is offline
post #3 of 4 (permalink) Old 12-05-2014, 09:15 AM
Parts Pimp
ChiefSmokeDawg's Avatar
Bike: 2002 R6, 2008 R6
A&D rods are 6mm on one end and 8mm on the other. This works with OEM rearsets and vortex.
Pull is correct for STD shift.
What rearsets do you have?
I have an expansion module that was slightly bastardized, you could splice the wires from whatever unit you get into it. I think I just cut the wires above the male/female connector to use the unit as an ECU connected QS. I'd sell it for super cheap if you want it, or I could also flash your ecu to enable the QS to the ECU, and you don't need the expansion module.
Either way I could probably save you some loot. Shoot me a PM and I'll check the flash file to see if it is already enabled, if the flash is the latest one, etc. Reflash is super cheap too
I see in your signature you have bohemian rearsets.. I know they are a similar design to the sato's and I think satos use a 6mm rod on both ends. If the diameter of both ends of the rod are the same, then you probably need A&C rods
ChiefSmokeDawg is offline
post #4 of 4 (permalink) Old 12-05-2014, 09:31 AM Thread Starter
Pharaoh6's Avatar
Bike: '09 R6
Chief, thanks for the response. Hope all is well man. Let me give you call over the weekend to discuss. Can you PM me your number again? Thanks much
Pharaoh6 is offline
Quick (down)Shifter cj360v8 General Discussions 12 10-29-2015 09:54 AM
pull type quick shifter and quick shifter module MELK-MAN Bike Parts For Sale 2 04-28-2015 07:46 PM
Quick Shifter sublime4mylife Bikes + Parts + Gear Wanted 6 07-28-2014 08:58 PM
annitori quick shifter SlowAndOld Off Topic Talk 2 11-08-2011 04:24 PM
Using a quick Shifter racerboy434 Garage / Mechanical Help 1 04-22-2007 03:56 PM
