how to make the bike run cooler - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 15 (permalink) Old 03-04-2015, 03:44 AM Thread Starter
Bike: R6 2012
e best way will be adding add on radiator or change to race rad. but will changing to silicone hose reduce the temp? will removing thermostat helps too?
Yamaha YZF-R6 2012
blueblood is offline
post #2 of 15 (permalink) Old 03-04-2015, 03:55 AM
Pastor of Muppets
yuengling910's Avatar
Bike: 09 R6, 07 R6S, 05 WR250F
Re: how to make the bike run cooler
Is it overheating?
You shouldn't need any additional cooling. Have you flushed the system and made sure you don't have any air in it?
yuengling910 is offline
post #3 of 15 (permalink) Old 03-04-2015, 04:27 AM Thread Starter
Bike: R6 2012
Originally Posted by yuengling910 View Post
Is it overheating?
its average at about 95-100deg c or abt 203-212 deg f
Yamaha YZF-R6 2012
post #4 of 15 (permalink) Old 03-04-2015, 08:20 AM
\_(ツ)_/
Bike: '09 R6R Raven
Sounds about right. I just put Engine Ice in mine. Dropped it a cpl degrees. Also, an ECU reflash can adjust the temp at which the fan comes on. Getting mine done now, and will have the fan kick on at 205.
modrid81 is offline
post #5 of 15 (permalink) Old 03-04-2015, 08:24 AM
Official Noob Greeter
redisdeadrideblue's Avatar
Bike: stupid ones and a Prius
I didnt notice any change with silicone hoses. Maybe a few degrees at best. The only way to really make it run cooler is to put in a bigger radiator, which is not cheap.
When you want to win, when there is no substitute for the best, when you don't want to feel the sting of second place, you really only have one place to turn.
EDR Performance, because their fast is faster than everyone else's
redisdeadrideblue is offline
post #6 of 15 (permalink) Old 03-04-2015, 08:26 AM
Mr. HER6
HIS OWN 6's Avatar
Bike: 08 R6, 15 Ninja300
Sounds like you don't have a problem. As long as it's working properly, the stock cooling system is plenty capable of maintaining proper operating temperatures. And no, changing out hoses isn't going to do anything to effect that.
HIS OWN 6 is offline
post #7 of 15 (permalink) Old 03-04-2015, 10:59 AM
Mott Power's Avatar
Engine Ice would be the cheapest, silicone hoses don't dissipate heat but are only a means of withstanding higher temperatures to prevent warping/melting (i.e. hoses close to the exhaust header or engine block). But it's not much of an issue for modern engine designs now-a-days.
CCS #414
Mott Power is offline
post #8 of 15 (permalink) Old 03-04-2015, 07:25 PM Thread Starter
Bike: R6 2012
Did change coolant to engine ice. Notice a temp drop during highway riding but when it come to track,it doesn't seems to make any effect. Maybe is becos my location is Veri hot n humid.
Reducing temp will also reduce power loss n also prolong engine life
post #9 of 15 (permalink) Old 03-04-2015, 08:36 PM
"The Dude abides .. "
MELK-MAN's Avatar
check your air to fuel ratio on your fuel map. You could richen the map up a tad in some places, as that will lower temps on track a bit (may loose a tiny amount of hp).
212F on track is not horrible. It's not uncommon to see 100c (212f) while racing in the hot months here in FL.
I would leave the thermostat in. Check some obvious stuff too, like the condition of your radiator fins.
As stated above, a larger radiator is VERY expensive, and just shouldn't be needed ..
MELK-MAN is offline
post #10 of 15 (permalink) Old 03-05-2015, 05:16 AM
Why yes I don't!!!!!!!!!!
TurboBlew's Avatar
Bike: 2007 In Heaven
just so its not unnoticed... going from standard mixed glycol (50/50) to engine ice nets some cooling because engine ice is premixed not because its that much better of a coolant. Engine ice is still glycol based.
The trick in high humidity/temp environments is to reduce the glycol content so your radiator can shed heat effectively. I would be be paying attention to oil temps before coolant temps anyways. Thats your primary cooling fluid.
Plumbing in an auxillary radiator is not too difficult. If your oil temps are sky high...youre never going to cool it down without an auxillary cooler. There is a water cooled one already... may just need to increase capacity. You can also increase the pressure of the radiator cap.
TurboBlew is offline
Wanting to make my r6 run like a 1000cc Tonyp436 RACE Section 69 09-02-2013 02:49 PM
Help! Bike won't run smooth after I run out of fuel FramedReality Garage / Mechanical Help 30 07-03-2013 11:41 AM
Bike wont start in cooler temps 07r6FL General Discussions 3 11-03-2009 07:48 AM
About to make a run - any advice?? Gandhi SR General Discussions 2 10-24-2009 10:40 AM
How To Make Your Bike Run Cooler gravis86 General Discussions 16 07-16-2008 07:44 PM
