Racers/Trackday Geometry settings - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 12 (permalink) Old 07-29-2015, 10:42 PM Thread Starter
Turn 1 = a Trip 2the Moon
vonstallin's Avatar
Bike: 2011 R6 & 2011 ZX10Rs (2)
Mostly with the forks...
Do you change your fork height for track days or racing?
The forks in stock settings look pretty tall in the tripple tree.
With certain tires are you guys changing geometry much? if so what combination?
I plan on using Pirellis SC, SP and superbike Pros.
I was depating on slapping on a 200/55 SC rear I have for now, then go back to 180/60 SC after the next TD.
I am trying to get her set up decent b4 the first ride.
I took her on a short test ride and was surprised how stiff the stock suspension was (set at full hardest) 245lbs my weight
  • To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
    (On FB) WERA Nov# 325/ CCS Nov# 326
  • 2016 ZX10R ABS (Street) |
    ABS (Street) |
    (Superbike Race) |
    | 2009 WR250F
vonstallin is offline
post #2 of 12 (permalink) Old 07-30-2015, 01:44 AM
Pastor of Muppets
yuengling910's Avatar
Bike: 09 R6, 07 R6S, 05 WR250F
Re: Racers/Trackday Geometry settings
Stock springs? Doesn't look like much preload is dialed in the front.
yuengling910 is offline
post #3 of 12 (permalink) Old 07-30-2015, 02:56 AM
Rubber side down
DarkravenR6's Avatar
Bike: 2006 R6 Raven
Actually that preload is cranked down all the way. Depending on what fork year and if they're still stock you look like your have the front lowered by 5mm.
2006 Yamaha R6 Raven
DarkravenR6 is offline
post #4 of 12 (permalink) Old 07-30-2015, 08:33 AM Thread Starter
vonstallin's Avatar
I picked the bike up in February.
It sat outside in some dudes back yard since summer 2013.
Ive done most of the rebuild on it, but I am a Kawasaki person and not sure where the forks are suppose to be set up to.
It was crashed 2 times b4 I got it and they replaced the stock clip ons with after market and i can tell the person who painted and put the bike together did not know what he was doing.
Im 245 lbs so I just cranked the preload all the way stiff, but in testing the bike its too stiff, and I do plan on getting my sag set and I can fine tune it myself, but I was wondering if guys who predominantly run there bikes on the track change the fork height ?
example:
On all my zx10Rs I generally raise the forks tubes 5mm, while most zuki 750 owners push the fork tubes down 5mm below the top tipple clamp.
    ABS (Street) |
    (Superbike Race) |
    | 2009 WR250F
post #5 of 12 (permalink) Old 07-30-2015, 08:36 AM Thread Starter
vonstallin's Avatar
Ok, I kinda figured it might need to go down some. Its stock forks and 2011.
I heard someone else tell me the forks need to change for track duty...but they never told me where lol...or how much in what directions and since I knew the bike was put together by an amateur I wanted to set her up for the track.
    ABS (Street) |
    (Superbike Race) |
    | 2009 WR250F
post #6 of 12 (permalink) Old 07-30-2015, 12:03 PM Thread Starter
vonstallin's Avatar
Ok i found the geometry settings i was told....
forks have 9mm showing
shock is shimmed 5mm to 9mm
Do anyone on the track run this geometry set up?
    ABS (Street) |
    (Superbike Race) |
    | 2009 WR250F
post #7 of 12 (permalink) Old 07-30-2015, 01:49 PM
Why yes I don't!!!!!!!!!!
TurboBlew's Avatar
Bike: 2007 In Heaven
heres some starting #s from the Suspension thread sticky. Last few pages have recent posts
TurboBlew is offline
post #8 of 12 (permalink) Old 07-30-2015, 08:02 PM
R6 New Racer
Vos go check the WERA board and ask Melk. Or ask Melk on here. What I have heard and what mine is set at is 293 (stock height) rear shock and I believe Thermosman said 525 on the forks. I am in the process of converting my 07 to as much 08 as I can.
cajun636 is offline
post #9 of 12 (permalink) Old 07-31-2015, 06:56 AM
Schwizard's Avatar
Bike: 2008 R6 Race
This is the ever on-going struggle for a lot of people. I don't understand what's so secretive about geometry, but I've asked multiple times on WERA and seem to get half answers or people asking additional unrelated questions. These people know their stuff, but for some reason, they aren't keen on handing out baseline numbers.
First off: You don't measure front geometry by how much fork is stick through the top of the triples. Depending on what's in your forks, they are going to be different length. The correct way to measure is by putting the bike on a pin style front stand, and measuring from the top of the lower triple tree to the center of the axle. When measuring the rear, you take the length between each eye holes in the shock.
Each tire is different and will effect geometry different. Will you feel the difference? Unless you're a seasoned expert level racer, probably not. For example, the Dunlop GPA-Pro rear tire is taller than the Pirelli SC rear tire, so you would take that into consideration if you're comparing your setup with someone else's.
Your geometry is going to depend on the track. Are you setting your bike up to be fast in the long sweeping corners? Or are you setting your bike up to fast in the tight, technical sections of the track? This matters. If you are setting it up for the faster, long corners, then you want a more stable geometry setup. If you're setting it up for tight technical sections, you may want the bike to turn quicker, so you lower the front end.
I setup my 08 for the fast sections of the race track, and do my best to muscle it through the tight sections. Here's the baseline I started with: 525mm for the front and 293mm for the rear. Wheel base extended as far back as possible. Stock gearing, or 15/43. What I found to be important is that its easy to mask suspension issues by softening things up, but by doing so, you're sacrificing corner enter, or exit. So, it's important to have the correct spring rates in your shock and forks, and to setup the preload properly so that the spring stiffness is accurate. From there its just dialing in the rebound and compression.
Hope this helps you with a starting point.
-Jes CRA #426E
Bell Helmets, AXO, Leatt, Dunlop
Schwizard is offline
post #10 of 12 (permalink) Old 07-31-2015, 10:14 PM
"The Dude abides .. "
MELK-MAN's Avatar
you lost me at "200/55" on a 600
up in till just a few years ago, world superstock was still running 180/55, and wss riders had the choice between 180/55 and 190/55 . the 180/60 pirelli is only slightly bigger than 190/55's but still designed for a 5.5" r6 wheel. but a 200/55 is just too much tire for a 600, and will be harder to ride, slower to turn, and just silly in general.
and the reluctance to give geometry #'s isn't so much it's a secret, but it totally depends on the fork setup, where the fork bottoms, oil height, and a dozen or so other things. same with the shock. sure 292-297 is common, but you are trying to squeeze a 200 rear tire on the bike, so that makes lots of other stuff irrelevant. then add your 245lb rider weight, and it's just hard to say "this will work".
The 2008-current comes with 10mm of tube showing above the clamp, and a shim above a stock shock and 180/55 tire. put a 190/55 on there, and remove the shim. pretty simple.. ? but to expand on that is very tough, as many are running cartridge inserts in the forks, aftermarket shocks, and the like.
Axle position just depends too. there is no magic position. Some setups may like the axle forward, some back.
MELK-MAN is offline
07 vs 08 geometry difference? #79 Suspension settings 12 12-13-2013 10:33 AM
Adjusting geometry? Brzrkr Suspension settings 6 12-19-2012 09:12 AM
03 Geometry diz Suspension settings 3 06-04-2012 11:51 PM
wet settings vs dry settings 07yzfr1 Suspension settings 0 05-30-2009 06:21 AM
Geometry Program BRAVO Suspension settings 4 03-05-2005 04:47 PM
