Oil Containment - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 5 (permalink) Old 07-10-2019, 04:43 AM Thread Starter
PRM
Oil Containment
Looking into what all I need, and want, to do to a Ď14 R6 for track days and eventually racing. For racing, one of the many items Iíll need is an oil containment lower fairing. From what Iíve found, you have to go with an entire race set to get that. Once installed, how much effort is it to get the bike back to a street legal (lights) configuration? Are there other options?
PRM is offline
post #2 of 5 (permalink) Old 07-10-2019, 08:16 AM
Probably breaking stuff
Garage
Re: Oil Containment
I can swap back and forth between fairing sets in under a couple hours. It gets faster every time you do it. Probably easier to get track fairings and then use the stock rear end with light still in it and then put a removable headlight on the front to make it street legal.
If you can keep all of the bolts organized, then it should be extremely quick. But I can't keep bolts organized.
zackb15 is offline
post #3 of 5 (permalink) Old 07-10-2019, 10:51 AM Thread Starter
PRM
Re: Oil Containment
Thanks.
Looking at Armour Bodies, Hotbodies and BikesPlast. Any to avoid?
PRM is offline
post #4 of 5 (permalink) Old 07-11-2019, 11:32 AM
Garage
Re: Oil Containment
Depends how much you want to spend. Hotbodies is only worth it if you wait for their end of season sale (in the fall) and get them when they are half off.
I would check your local forums, fb group, track day org or racers and odds are is that someone is giving away a set of race bodywork for fairly cheap.
zackb15 is offline
post #5 of 5 (permalink) Old 07-12-2019, 02:33 AM
Why yes I don't!!!!!!!!!!
TurboBlew's Avatar
Bike: 2007 In Heaven
Re: Oil Containment
best are sharkskinz and armor bodies. Requires minimal adjustment. There are other cheaper brands BUT you will soon find out how they are garbage after a crash thereby negating your cheap cost.
As for putting the bike back on the street... not a good idea. I guess with LED lights you can add some headlights at the mirror mount areas and have a strip LED rear light with the racebody. Once you see how easy it is to service a bike with race body... you wont be going back to stock panels.
TurboBlew is offline
