Wheel hop? - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 12 (permalink) Old 08-12-2007, 11:44 AM Thread Starter
Bike: 2003 R6 Limited Edition
Wheel hop?
Ok being a fairly new rider with only a couple months under my belt, i have a question that i am unsure of. When i take some curves at a decent speed, specifically today, and im leaning into them, it feels as if my rear tire is weaving kinda. To give you an idea of the curvature, it is a 45 mph turn and i was going about 70 thru some and almost 80 thru other (very unpopulated back road) My buddy says its wheel hop but i dont know. Is this common? Ive got a 2003 and its lowered about 2 inches and i was in 6th gear if any of that matters. If anyone could just advise me of whats going on. Thanks
zuritausmc is offline
post #2 of 12 (permalink) Old 08-12-2007, 02:56 PM
Hate the 405
RadicalR6's Avatar
Bike: 07 R^6, 05CBR1k Repsol
Images: 10
Re: Wheel hop?
6th gear? thats too high for my liking. is your suspension set up correctly? if not it could feel like your loosing the back wheel.
RadicalR6 is offline
post #3 of 12 (permalink) Old 08-12-2007, 03:10 PM
Images: 1
Re: Wheel hop?
hows the back tire? is it new or worn out? and yeah i like having my rpm's high when im hittin twisties because well as we all know the r6 is a track bike but yeah how is the tire wear?
csok is offline
post #4 of 12 (permalink) Old 08-12-2007, 07:02 PM
2007 R6
Yam07R6's Avatar
Bike: 2007 Track R6
Images: 1
Re: Wheel hop?
IMO the wheel "hop" is from being in 6th gear and not having a smooth throttle. You need to gear it down a little and lowering your bike will make if feel heavy like that in a turn. I had mine lowered an 1" and put it back to stock because it road bad.
Yam07R6 is offline
post #5 of 12 (permalink) Old 08-12-2007, 07:17 PM Thread Starter
Re: Wheel hop?
The tire actually has really good tread, i guess i can try a lower gear and see how it responds. I just wasnt sure if it was the lowering
post #6 of 12 (permalink) Old 08-12-2007, 07:33 PM
Shiney up Rubber down
asdfjklm's Avatar
Bike: 04 Red R6 and 09 White R1
Images: 82
Re: Wheel hop?
Yeah sounds like something's missing from this story, BUT if I may suggest, If you're in the turns/twisties, you should be in a MUCH lower gear than 6th.
USUALLY when I'm in the turns and stuff I run 2nd or 3rd gear. Don't be afriad to run those RPM's up, the bike was made to run High revs. Just be careful because in lower gears at higher revs your bike will be much more responsive (than running it in 6th gear at the same speed)
As for the wheel hop, you may have had anything happen from choppy throttle, to running over a rock, hitting a crack in the road, running over tar, even a leaf will make your wheel move some if you're leaned over enough.
Have fun and stay safe out there.
ZW
PHANTOM.... DID YOU BUY A BIKE YET?
asdfjklm is offline
post #7 of 12 (permalink) Old 08-12-2007, 07:35 PM
Paytheon's Avatar
Images: 61
Re: Wheel hop?
And always make sure you've done your braking "before" you start cornering. That helps out a lot.
Paytheon is offline
post #8 of 12 (permalink) Old 08-12-2007, 07:37 PM
asdfjklm's Avatar
Images: 82
Re: Wheel hop?
Right-o
ZW
asdfjklm is offline
post #9 of 12 (permalink) Old 08-12-2007, 09:33 PM
Dragging Knee
mojo's Avatar
Bike: Blue 2006 R6
Send a message via AIM to mojo
Re: Wheel hop?
Get your bike's rpm's up it will feel much more stable when you are down a few gears. Also it sounds like you don't have the suspension set right.
Blue because it is faster.
mojo is offline
post #10 of 12 (permalink) Old 08-12-2007, 11:20 PM
Ya wheelies is garbage!
~03~Raven's Avatar
Bike: 03 R6
Images: 39
Re: Wheel hop?
Ya unless for some reason you just want to straightin the bike come out of the apex and through the ditch.
~03~Raven is offline
How To: Remove Front/Rear wheel, Adjust Chain Slack, Align R BrandonClaps How To's... 33 11-05-2011 07:49 PM
high side?? nybimmer General Discussions 22 03-09-2008 07:50 AM
Bang wheel lip out (straight) or buy new wheel? BaileyMotorSports General Discussions 7 06-25-2007 07:09 PM
R6 front wheel for sale parapuke Bike Parts For Sale 14 12-13-2006 04:34 PM
How To: Remove Front/Rear wheel, Adjust Chain Slack, Align R BrandonClaps How To's... 0 09-09-2004 09:43 PM
