Anti-Freeze Options???? - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 9 (permalink) Old 10-02-2007, 07:42 AM Thread Starter
2007 R6
Yam07R6's Avatar
Bike: 2007 Track R6
Images: 1
I have been using water instead of antifreeze for track days because of the requirement. The bike seems like it is running hotter. Does anyone know of another good substitute for antifreeze. Thanks for any info.
2007 R6 - O2 Carbon Tank Cover, GYTR Carbon Fiber rear tire hugger,Carbon Fiber Swingarm covers,Carbon Fiber Front Fender, MCarbon side covers, MCM Carbon Fiber Stator Cover and Clutch Cover, Ohlins Rear Shock, Ohlins Fork Internals and Seals, Yoshimura Header w/ DTC Carbon Pipe, Dynojet PCIII, Driven F/R Sprockets +2 Rear and -1front, Carbon Fiber heel guards, Tuner X Frame Sliders, Pazzo Levers, RK 520 Chain, BMC air Filter,Rizoma Grips and Bar Ends, GPR V4 Damper, Woodcraft Rear sets,DMS Rear Wave Rotor, Galfer Brakelines, BT003 Race Tires, Ferodo Brake Pads,PIT-ECK Race Body,
Yam07R6 is offline
post #2 of 9 (permalink) Old 10-02-2007, 08:28 AM
Go Tigers!
DaddyPhatSaks's Avatar
Bike: 2001 R6-2002 CBR954 Track
Re: Anti-Freeze Options????
Engine Ice, not sure if you can run it on the track tho
I use waterwetter, but no anti freezing ablilties.
2001 R6 - 2002 CBR 954 Track - 2004 Nissan 350z
DaddyPhatSaks is offline
post #3 of 9 (permalink) Old 10-02-2007, 08:40 AM
Go Tigers!
OK with STT, Approved Poly Glycol brands are: Evans, 7th Gear, Liquid Performance, and Engine Ice.
post #4 of 9 (permalink) Old 10-02-2007, 08:43 AM
Go Tigers!
Nesba: Engine Ice and Evans-type coolants are NO longer permitted! Water Wetter is permitted.
post #5 of 9 (permalink) Old 10-02-2007, 08:59 AM
why the different rules between organizations?
jjm004 is offline
post #6 of 9 (permalink) Old 10-02-2007, 11:43 AM Thread Starter
2007 R6
Yam07R6's Avatar
Bike: 2007 Track R6
Images: 1
Yeah I noticed that recently. I guess I will try Water Wetter, Thanks for the info.
Yam07R6 is offline
post #7 of 9 (permalink) Old 10-02-2007, 12:49 PM
Go Tigers!
No problem, just remember water wetter will freeze.
post #8 of 9 (permalink) Old 10-02-2007, 05:36 PM
crashing aint so bad
luke geis's Avatar
Bike: 2005 red r6
Images: 10
water wetter is the popular one. It will keep the engine running at normal temps and will provide corrosion protection. You must use it in conjunction with DISTILLED water though for the proper results. As mentioned it will freeze if it is that cold in your area. For most of us though that is not an issue.
luke geis is offline
post #9 of 9 (permalink) Old 10-02-2007, 06:05 PM Thread Starter
2007 R6
Yam07R6's Avatar
Bike: 2007 Track R6
Images: 1
Thanks Again for the info. This is the last track event for the year so I will swap it out when it's over so no problems with freezing.
Yam07R6 is offline
Anti theft devices. trapspeed General Discussions 10 04-08-2007 03:41 PM
Track options? Stunt4Life General Discussions 31 03-04-2007 10:43 AM
anti picture radar???????????? alejandrofm1 General Discussions 7 03-17-2006 04:33 AM
Rear Seat Cowl - suggestions and options welcome... Ragnarok Appearance and Exterior Mods 1 05-16-2005 11:32 AM
