ike is shaking when leaning - need HELP - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 13 (permalink) Old 12-02-2007, 06:11 PM Thread Starter
I m starting to eat my R6
GEORGERE's Avatar
Bike: 06 R6s-Blue; 1-hp rented
when i lean my bike to the left (this never's happened on the right lean though), on curvy turns, the bike is shaking pretty bad.... i think its the rear end vibration but i m not sure..... i m almost positive this isnt due to improper throttle use.... so, can this be?
1. chain lube got on the rear tire (i make sure i wipe it off when this happens....) i think the "shake" happens even after a while since the chain was lubed
2. improper riding technique
3. something wrong with suspension, swing arm, rear tiere assembly, tire threads
will highly appreciate your thoughts on this problem
thanks in advance
06 R6s Blue
MIVV GP Slipon ~ PC USBIII ~ BMC Air Filter ~ Custom Map ~ Shogun Crash Kit ~ Pazzo Short Levers ~ Driven Gel Grips ~ Fender Eliminator Kit ~ Euro Effects HID Conversion Kit 4300K
GEORGERE is offline
post #2 of 13 (permalink) Old 12-02-2007, 07:28 PM
Zombies may bite!!!!
rchristian56's Avatar
Bike: 2007 Yamaha R6
Re: ike is shaking when leaning - need HELP
Where are you getting the shaking?
What kind of shaking?
This is a really hard one just on your description, sorry.
rchristian56 is offline
post #3 of 13 (permalink) Old 12-03-2007, 05:53 AM
based on your vague discription of what is happening, i would say it could be a number of things, and can throw out a couple you said
1. It is either like you said, improper throttle, or distribution of weight as you turn, if you go into a turn shaky, you will more than likely botch the turn and cause riding issues. If you do not have a steady throttle your distribution on tire will be effected, if you decelerate or quickly blip it, it will cause your end to come out slightly. But weight, are you moving your ass while in turn?
2. How bad are your tires, thread wise?
3. What are your suspension settings?
4. I can almost 100% say that it is not your chain lube used getting on the tire.
just my 2
Script' is offline
post #4 of 13 (permalink) Old 12-03-2007, 10:21 AM Thread Starter
GEORGERE's Avatar
guys, thanks for your input....
rchristian56, the rear of the bike is like dancing left to right.... something like i ve seen in a video when high-side happens...
Script', my tires are prob fine especially that this doesnt happen to the right side.... i have no idea what my suspension settings are.... the bike is pretty much stock - i got it 1-year used and havent played with suspension yet.... i would say this can be the throttle (even thoug i'd like to think i m controlling it well) or improper position.... i havent been moving my ass until recently (i dont think i was when the rear-end vibe was happening) however i never heard they move asses on cruisers... my point here is that basic riding position would not cause this problem, would it?
will appreciate your further thoughts on this matter....
How/what needs to check to id suspension settings? (perhaps the previous owner was playing with it)
06 R6s Blue
GEORGERE is offline
post #5 of 13 (permalink) Old 12-03-2007, 05:26 PM
Georgere I'll get back to you tomorrow but I'd chekc the air pressure first.
Then we will talk about setting up suspention and how to.
I would say other things about ridding style but you make it sound like these are low spped turns and a confedence or riddind style does not really play into hand unless we aare talking hirer speed turns where your cranked over.
post #6 of 13 (permalink) Old 12-03-2007, 07:35 PM Thread Starter
GEORGERE's Avatar
Re: bike is shaking when leaning - need HELP
another thought: can this be that my tire get affected due to the bike is always on the kick-stand when parked - i.e. leaned to the left (my garage is too small to put the bike on a rear stand like pitbull)? i've heard this can cause issues with the tires.....
06 R6s Blue
GEORGERE is offline
post #7 of 13 (permalink) Old 12-04-2007, 08:57 AM
Yeah if it was sitting for months at a time and I would even say it wouldnt be noticable until at least a year of non movement in one spot.
Are you the first onwner?
And is this an issue has the bike been sitting for long periods of time?
post #8 of 13 (permalink) Old 12-04-2007, 09:36 AM Thread Starter
GEORGERE's Avatar
if you saying that this would take months for the tire to be affected by the bike/tire standing in one spot, then we can rule out this as an issue....
i m 2nd owner..... i've been a pretty active rider (on weekends only though) and put on over 3500 miles in one season....
06 R6s Blue
GEORGERE is offline
post #9 of 13 (permalink) Old 12-04-2007, 10:05 AM
how old is the tyre in question?
gav2k is offline
post #10 of 13 (permalink) Old 12-04-2007, 01:42 PM
The part thats really getting me is the one siddedness of this issue.
Do me a favor turn the slots on the fork tops counter clockwaise counting clicks. Write the clicks down for both sides this way you remember how many times to turn them clockwise back.
See if these numbers match.
reverse leaning? icepic General Discussions 33 05-25-2008 04:58 PM
Leaning??? herman818 General Discussions 18 11-28-2007 10:21 AM
Bike Leaning to the Right at high speed???? MPH05 General Discussions 5 09-17-2007 12:49 PM
handle bars shaking wncr6_50th Garage / Mechanical Help 6 07-04-2007 11:24 AM
leaning the bike? bpowa General Discussions 29 12-09-2005 10:07 AM
