Securing race tail 2003 - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 8 (permalink) Old 05-03-2008, 07:25 PM Thread Starter
I have a new tail piece I want to attach to the track bike I have (2003 R6). The old one attached with two bolts by the battery and two bolts where the seat bolts into the sub frame then it was zip tied at a few holes in the under tail. The new one has spots for two bolts by the battery but none where the seat bolts on. The new tail has a recessed spot on top for a bolt but I can't see it lining up with anything directly below it. Anyone have any advice? Do you have to fabricate something for the recessed bolt hole on top? Thanks
R6nZX10R is offline
post #2 of 8 (permalink) Old 05-03-2008, 10:53 PM
Re: Securing race tail 2003
The two cutouts are so your stock seat bolts can still hold the seat on. The two tabs by the battery are for the black plastic push pin type thingies and the rear recess does have a bolt hole directly below it. I think it was originally a taillight mount or something like that, but if you drill a hole there, there should be threads to put a bolt into.
Agent4573 is offline
post #3 of 8 (permalink) Old 05-04-2008, 05:17 PM Thread Starter
Thanks for your response. The old tail, where the two slots are for the seat bolts have extended surfaces so the seat bolts can go through those points as further reinforcement. That's why I am baffled as to why they wouldn't do the same. Thanks
R6nZX10R is offline
post #4 of 8 (permalink) Old 05-04-2008, 09:45 PM
Images: 2
I just put the two push pins by the battery and never had any problems. what type of race skins do you have? I have hotbodies your may be different.
bowtech is offline
post #5 of 8 (permalink) Old 05-05-2008, 06:42 AM
wat?
rhouck's Avatar
Bike: 09 R6, 14 Street Triple R
^ +1
I just ziptie the fronts on and it's good to go. It's a bitch to get on/off over the passenger seat mechanism anyway; there's no way in hell it's going to just fall off.
rhouck is offline
post #6 of 8 (permalink) Old 05-06-2008, 08:12 AM Thread Starter
Originally Posted by rhouck View Post
^ +1
Yeah I agree, it is a bitch to slide over the tail. I cut off about 1/2 inch of that plastic thingy on the right side so it goes on easy now. Thanks for your responses.
R6nZX10R is offline
post #7 of 8 (permalink) Old 05-06-2008, 09:12 AM
wat?
rhouck's Avatar
^ Oh I did that too and it still creaks and cracks. I don't even know how you did it with that plastic piece still on!
rhouck is offline
post #8 of 8 (permalink) Old 05-12-2008, 05:04 PM
+1 , I did mine the same way, push pinned the forward most holes and drilled that top hole and put a bolt in there. You can make it a little more sturdy if you drill two holes in the undertail plate right up at the far forward edge and insurt a couple bolts or push pins there, when its attached to the bottom of the tail section it will make it a little more sturdy but not required. The first thing I did was cut that plastic thing off the right side and I also removed the passanger seat mechanism.
recoil50 is offline
Race Tail - OEM Look Wanted R6init Appearance and Exterior Mods 0 01-05-2008 02:34 PM
WTB: Race Tail for an 05 R6 Raven_05R6 Bike Parts For Sale 0 01-02-2007 02:48 PM
2003 R6 RACE SLIP-ONS flyinryan Exhaust and fuel delivery 0 03-23-2004 03:36 PM
Race skins 2003 R6 dower General Discussions 6 02-23-2004 10:46 AM
Will superbike still race a Daytona? dj1298 General Discussions 0 12-31-2003 08:37 AM
