What tire pressure Bridgestone BT002 for track? - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 16 (permalink) Old 06-02-2008, 12:28 AM Thread Starter
tongphan's Avatar
Bike: 2007 R6r Track Bike
Question What tire pressure Bridgestone BT002 for track?
I am running the Bridgestone Battlax Bt002 Street/Track Day version tires on my 2007 R6 for track days. The pressure I've been running them at is 28psi front and 26.5 rear cold. I would like to find out what Psi should they be at when hot for optimal performance?
tongphan is offline
post #2 of 16 (permalink) Old 06-04-2008, 01:29 PM
Re: What tire pressure Bridgestone BT002 for track?
I used the BT002 Pro versions my last track day (Hard rear, Med front) and I rode 30 Front and 28 Rear. (Both HOT pressures)
Those were the pressure I got from a guy at a local shop that races WSMC and WERA with them.
R6LIFER is offline
post #3 of 16 (permalink) Old 06-04-2008, 02:17 PM
Dragging Knee
mojo's Avatar
Bike: Blue 2006 R6
Send a message via AIM to mojo
I ran the Bt002 RS which is the street/track tire.
I had good sucess with 30 front 29 rear (cold pressure) at the track.
Blue because it is faster.
mojo is offline
post #4 of 16 (permalink) Old 06-04-2008, 06:13 PM Thread Starter
tongphan's Avatar
Talking Re: What tire pressure Bridgestone BT002 for track?
Thanks everyone. I asked the tire guys at the track and I ended up running 28psi front and 26.5 rear cold pressure and it worked out great.
tongphan is offline
post #5 of 16 (permalink) Old 06-07-2008, 11:07 AM
I ran 27 front 26 rear(cold) on the bt-002 pros at putnam. loved em
carbon01gt is offline
post #6 of 16 (permalink) Old 06-07-2008, 02:43 PM
Team: Teletubby racing
fyrefyter0143's Avatar
Bike: 2004 r6,1973 norton
i ran micheline power race.......24 rear....29 front
Originally Posted by Mario J View Post
Dan for mod 2010!
Originally Posted by 408_grow View Post
id vote dan for mod
Proud Member of Team: TELETUBBY RACING
Suicide is NEVER the answer,
getting help is the answer.,1-800-273-TALK
godspeed Noodz
fyrefyter0143 is offline
post #7 of 16 (permalink) Old 03-16-2009, 09:08 PM Thread Starter
tongphan's Avatar
So I went to the track over the weekend and the guys at Bridgestone were there. They said to start out at 28psi front and 26psi rear cold and my target temp was 31-32 hot for both.
tongphan is offline
post #8 of 16 (permalink) Old 03-28-2009, 06:00 PM
Bike: 2008 R6
yea, i plan on running these on the track but when i ran them on the street on curvy roads id be around 31 32. id just start at 34 n lower it to how i think its working good. but i went down 1 pound at a time front n rear n took a while.
06r6sraven is offline
post #9 of 16 (permalink) Old 03-29-2009, 05:39 PM
crashing aint so bad
luke geis's Avatar
Bike: 2005 red r6
Images: 10
It's a tough one with those tires. I started at 28/28 cold and the front was perfect but the rear cooked. It ran up to 35 to 36 hot. I added a pound of air to cool it down and it did not make a difference. I ran the next day 28/29 Which is technically backwards for tire pressures. The rear still cooked up to 36 while the front was still at the perfect temp of about 34. I was running about mid pack in the A group so I may have been running a little faster than the tire were really designed for. They had good grip for a couple of laps and then they would fall off very quickly getting worse each lap. By the end of the second day I had to quit early as they would not provide any grip. The sad thing was that the tires still looked as if they had plenty of tread left to run. They were shot from being cooked. These tires are perfect for a solid B group rider that is running a good pace. If you are an A group rider that is pushing in the middle to upper 2/3 of the pack in lap times they will just not be able to handle the stress. They need a lot of cold tire pressure to get the tire in the operating range but wil not provide enough grip unless you run the lower pressures. I still love the bridgestone bt002's as a street tire. they are to me superior to the the 2ct's which would not handle the faster lap times very well.
luke geis is offline
post #10 of 16 (permalink) Old 03-29-2009, 06:12 PM Thread Starter
tongphan's Avatar
Great info guys.
I use them in the B group and work just fine.
I can understand how they cant hang in the A group.
tongphan is offline
Pirelli Diablo Rosso Press Release SpidermanSS Main Page News 45 04-22-2008 12:06 PM
Stock Tire Pressure - Recs & Y? Jeramie Tire Tech Talk 2 07-31-2007 03:30 PM
Supercorsa Pro users, tire pressure questions. DaddyPhatSaks Tire Tech Talk 11 05-17-2007 05:01 AM
Determining Best Tire Pressures james1300 General Discussions 0 11-17-2006 08:12 AM
Tire Air Pressure Ed Tire Tech Talk 2 08-05-2004 05:00 PM
