Cruising RPM - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 28 (permalink) Old 06-04-2008, 08:18 PM Thread Starter
Its Only a 600?
Bozzo06's Avatar
Bike: 2007 R6 (Blue)
Send a message via AIM to Bozzo06
Cruising RPM
Hey guys, I just wanted to know what RPMs you are at when just cruising? I know running to low will go through spark plugs, and i'm sure running high has it's cons.
CW Flush Mounts, CW Fender Eliminator, Puig Windscreen, GYTR Slip On, TapeWorks Rim Tape,6000K HID, PFW Mid Pipe, PCIII, 2007 AMA Decals, Pazzo Levers, Shogun Frame Sliders, C/A Int Tail Light, Seat Cowl.
Bozzo06 is offline
post #2 of 28 (permalink) Old 06-04-2008, 08:33 PM
I do it for the Chicks.
Bike: 2007 YZF-R6S
Send a message via AIM to Kolk1 Send a message via Yahoo to Kolk1
Re: Cruising RPM
Considering I normally use my bike to go to work and back on the Highway, Im normally around 6k-7k rpms
07 Glare White R6S, bought brand new in April 08. Current mods, Power Commander with dyno tune, K&N air filter, Yosh Carbon fiber Slip on, Smog Block offs, Slide stops, 520 Conversion with EK ZZZ chain, with -1/+2 sprockets, Speedo Healer, Black Puig DB, 4300 HID kit, Frame Sliders, Spools, CF tank guard, Vortex rear peg delete, front flush mounts, shaved seat, rear seat delete, DMP front and rear stands, Black levers, black rear sets, and soft grips.
Kolk1 is offline
post #3 of 28 (permalink) Old 06-04-2008, 09:25 PM
rideblue51's Avatar
Bike: 2008 R6 Cadmium Yellow
Re: Cruising RPM
Same for me, 6k-7k+, stock gearing. I live out in the middle of nowhere so I can go a little faster out here. Plenty of room right out the front door to get her up to 170mph! Good mountain roads too!
rideblue51 is offline
post #4 of 28 (permalink) Old 06-04-2008, 09:32 PM
Bike: 2007 YZF-R6S
Re: Cruising RPM
I have a -1 front sprocket. But I usually go between 55-70mph depending on which highway im on.
Kolk1 is offline
post #5 of 28 (permalink) Old 06-04-2008, 09:45 PM
Paytheon's Avatar
Images: 61
Re: Cruising RPM
With gas prices like they currently are? My RPM on the streets is much lower.
Paytheon is offline
post #6 of 28 (permalink) Old 06-04-2008, 09:47 PM
Dan the man
dang387's Avatar
Bike: 07 R6s
Send a message via AIM to dang387
Re: Cruising RPM
5k-6k
"Life moves pretty fast....if you don't stop and look around every once in a while you might miss it"
dang387 is offline
post #7 of 28 (permalink) Old 06-04-2008, 10:21 PM
Lifetime Premium
Owen_R6's Avatar
Bike: 08 Blue R6, Red 03 (sold)
Re: Cruising RPM
i'm usually around 5-6...used to run around 4
Bike:
2008 Yamaha R6 - Full Graves system, KN filter, PCV with Autotune, Agg block offs, Bauce ECU, Ohlins damper, Shermoto levers, Vortex rearsets, flush fronts, integrated rear, Zero Gravity screen, black passenger pegs, LP sliders, LP spools, and more to come.
Cage:
2012 Nissan Frontier King Pro-4X
Sold:
2003 Yamaha R6 - LOR Exhaust, PC3, Velocity Stacks, Block offs, BMC Race, Custom Tune, 520 15/50, Speedohealer, Spiegler brake lines front and rear, Custom paint, Custom wheels, Smoked flush fronts, Smoked integrated rear, Zero Gravity screen, Shorty levers, Driven grips, Powdercoated rearsets and pegs, sliders, spool, and probably more I'm missing
Owen_R6 is offline
post #8 of 28 (permalink) Old 06-05-2008, 10:03 AM
Dragging Knee
mojo's Avatar
Bike: Blue 2006 R6
Send a message via AIM to mojo
Re: Cruising RPM
10,500+ on the track.
On the street 5000-8000 range when cruising.
Blue because it is faster.
mojo is offline
post #9 of 28 (permalink) Old 06-05-2008, 10:04 AM
Re: Cruising RPM
6-8Kish
Manoah is offline
post #10 of 28 (permalink) Old 06-05-2008, 10:12 AM Thread Starter
Its Only a 600?
Bozzo06's Avatar
Re: Cruising RPM
alright guys, thanks for the help.
Bozzo06 is offline
Shift patterns / good cruising RPM Snoobies Garage / Mechanical Help 9 02-21-2013 09:15 PM
Street cruising, what gear? R6Pnoy General Discussions 28 02-07-2008 01:43 PM
cruising speed on highway ?? :} grim-r6 General Discussions 26 01-09-2008 03:42 PM
Cruising Ribbs2521 How To's... 8 07-02-2006 10:55 PM
optimal cruising rpm's ARESIX RIDER General Discussions 12 04-16-2006 05:02 PM
