Keyless start?? - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 39 (permalink) Old 12-07-2008, 06:19 PM Thread Starter
raven24's Avatar
Keyless start??
Just wondering if anyone could tell me what i need and how i would wire in a keyless start for track days. thanks (pics would be get if possible)
raven24 is offline
post #2 of 39 (permalink) Old 12-07-2008, 06:26 PM
08 Yamaha R6
longbrake_00's Avatar
Bike: 08 Yamaha R6
Re: Keyless start??
Only thing I have every really seen on this.
Most don't do it because it makes it that much easier to steal the bike.
Mods:
Full Leo Exhaust, PC III, Graves Smog Block Offs, GYT-R High Flow Filter, Barnett Race Clutch, Vortex Sprocket Conversion, DID Racing Chain, GPR Steering Damper, Smoked Galfer Brake Lines, Samco Coolant Hoses, Carrozzeria Rims, Pazzo Levers, Moto-R Engine Covers, Acumen Gear Indicator, Bohemian Racing Rear Set, Speedo Healer, Graves Frame Sliders, Moto-R Spools, Knight Rider/Solid Third Eye, Gorilla 7017 Alarm, Graves Bar Ends, CRG Hindsight LS Barend Mirror, Spider Grips, Pro Bolts Fairing Bolt Kit, Lightech Engine Bolt Kit, Solo Cowl, GYT-R Black Axle Adjusters, Hotbodies Flush Mounts, Graves ExUP Removal, Puig DB Screen, Cox's Radiator Cover, Fender Eliminator, CA Tail Light, Lawstcaws Frame Plugs, Passenger Peg Covers, Stomp Grip Pads, Black Kickstand, Harris Gold Gas Cap, Carbon Tank Pad, Lightech Gold Oil Cap, Light N'Boltz, Puig Toe Guard, Race Rotors, Lamin-X Headlight Covers, Traxxion Tank Sliders, R&G Exhaust Slider, Rizoma Front and Rear Axle Sliders, PlanetSuperBikes Number Plates, Vortex Mirror Block Offs
longbrake_00 is offline
post #3 of 39 (permalink) Old 12-07-2008, 06:29 PM
08 Yamaha R6
Bike: 08 Yamaha R6
Re: Keyless start??
Found this not sure how close it would be, and looks like the pics don't work
Mods:
post #4 of 39 (permalink) Old 12-07-2008, 06:32 PM Thread Starter
raven24's Avatar
Re: Keyless start??
cool thanks
raven24 is offline
post #5 of 39 (permalink) Old 12-07-2008, 07:48 PM
Re: Keyless start??
disconnect the 4 wires going to the ignition. Put a toggle switch between the two thicker wires, connect the two thinner wires together. Tada! you're done.
Agent4573 is offline
post #6 of 39 (permalink) Old 12-08-2008, 03:46 AM
mailbox killin' werewolf
frankieg22x's Avatar
Bike: 06 ZX636
Images: 6
Re: Keyless start??
I'm gonna try this for now just to see if she will start. I havn't gotten a chance to try since my key went missing during my accident. Do you have to cut any wires or anything?? Would i be able to reconnect these wires to a new ignition down the road??
Thanks
frankieg22x is offline
post #7 of 39 (permalink) Old 12-08-2008, 05:28 AM
08 in the crate
Bike: 08 Silver R6, 04 600rr
Re: Keyless start??
$100 for that!!!!!
If you have your ignition off the bike what you can do is cut the wires after the plug because you don't have the key anyway then you can plug in the connection and solder the two smaller wires together and put a switch on the two bigger wires if that is how it's wired. Then you can pull the plug off if you get another ignition. Another option that we have done is wire the ignition into the run/stop switch making it the ignition and the run button. Then you don't have to buy anything, just hook it up. T
tripage is offline
post #8 of 39 (permalink) Old 12-08-2008, 06:29 PM
Re: Keyless start??
Thanks
When you cut the wires just leave enough on all the original connectors so that you can solder them back together later. That way if you change your mind you can redo the ignition.
*EDIT, If i remember correctly, the thicker wires on the bikes harness can have male spade connectors inserted, so you won't have to cut that connector off. The two thinner wires can probably have a little jumper wire made the same way, with either male or female space connectors shoved into the wiring harness.
post #9 of 39 (permalink) Old 12-08-2008, 06:44 PM
www.1seven1.com
danaatscootdotnet's Avatar
Re: Keyless start??
On my old R6 race bike I ran a 12v relay in the ignition lines and tripped the relay with voltage running through the kill-switch on the handle bars. It worked pretty slick ... no need for a key and the ignition went off when you flipped the red button.
On my new race bike I just safety wired wired the key into the ignition.
danaatscootdotnet is offline
post #10 of 39 (permalink) Old 12-09-2008, 04:58 AM
Bike: 06 ZX636
Images: 6
Re: Keyless start??
i was looking at it last night. It looks like i can just cut the wires about 3-4 inches after the connector and put the two small wires together to one side of a toggle switch and the two larger wires to the other side of the switch. If i cut the wires before the connector i should be able to just unplug the ignition wire plugs and plug a new ignition module into it when i get a new one right? My ignition is crushed pretty bad from when the bike went end over end down the highway. I just want to do this temporary to see if it will start. I am going to get a new ignition and lock set that comes with a key off ebay in the spring.
Keyless start raven24 How To's... 4 12-10-2008 06:57 AM
01 wont start - battery?? - was fine two days ago! AMERCANZERO Garage / Mechanical Help 12 12-13-2007 05:53 PM
Hard Start foxmotoracer23 Garage / Mechanical Help 4 04-19-2007 09:48 PM
How To: Battery dead? Rolling start! gfraisse General Discussions 7 03-16-2007 07:00 PM
HELP..Bike won't start after stator replacement! RuffRhyno Garage / Mechanical Help 2 08-10-2006 09:48 PM
