1 - 9 of 9 Posts
Just another r6'er
So I'm installing my pcv and autotune and I can't find the o2 sensor plug under the tank. So i decided to remove my o2 sensor since i need to change it anyways and trace it.
Anyways when i disconnected the exhaust o2 sensor i found this (pic attached) What are these two wires? They weren't connected at all. I guess the previous owner disconnected? Is it okay to remove completely with the 02 sensor?
thanks,
Just another r6'er
Just another r6'er
Just another r6'er
perfect thanks
As mentioned above, don't remove the servo without buying or making an EXUP plug. I just bought one, as it was easier, but it wasn't exactly cheap. MJS usually has them in stock.
Just another r6'er
Yeahh, i remember seeing the threads about how to remove it. I knew where the motor was and all just never knew those were the cables. I'm leaving them there, in the winter i will be removing it, plus lots of other mods :D
1 - 9 of 9 Posts
