1 - 20 of 21 Posts
02 R6 parts lots-$100 takes all
what's left: 4-1 header, wiring harness, frame, upper rear alum frame with right rear sets, swing arm, gas shock, rim/tire/rotor/axle, rear brake caliper/bracket, res tank, hose, rear brake master, shifter/rod, right front foot peg/bracket, misc electrical, fuel tank, petcock, phone only, pickup at shop door price , osoyoos bc $100, no text, no calls after 8pm pacific, 1 250 495 344five
Discussion Starter #8
my buddy talked me out of the engine, will leave what's left in case anybody needs something. Carbs, wire harness, bars, air box, solenoid, rear brake system, rear sets, yellow shock, etc
Discussion Starter #10
02 R6 new owner with parts bike.
Apparently I will be not be able to post an ad in the parts section until after 0615 hrs on 18 march 2019.
Discussion Starter #11 (Edited)
I posted an ad in the parts for sale section which was deleted twice... as I did not post a picture or price. Whoever wants what is left from this 2002 Yamaha YZF-R6, please come to shop door with $195 Cdn dollars and you can have everything left. LIST : frame, swing arm, rear rim, tire, rotor, axle, wiring harness, tach, misc box of signal parts, upper rear alum frame with rear sets, fuel tank, fuel petcock, front brake master cylinder, shifter/rod, rear caliper/bracket, hose, res tank, rear master, misc plug ins to harness, 4-1 front header pipe, side stand, throttle sleeve, some misc alum pieces for frame, I have carefully inspected these parts and they are clean, safe to use, stored inside, bring your own boxes, no camera or cell phone, cannot post picture..... $195 osoyoos b.c 250 495 344five. No calls after 8pm pacific,
Discussion Starter #14
Parts left: wiring harness, rear shock, pair of bars, tach, rear brakes, swing arm, rotor, axle, rim, upper alum rear section, fuel tank, side stand, left and right controls, shifter/rod, solenoid, header pipes, phone only 1 250 495 344five, no calls after 8pm pacific,
Discussion Starter #15
Parts left: wiring harness, rear shock, tach console, res tank, hose, rear brake lever/bracket/foot peg, rear brake master, rear caliper/bracket, rear rotor, rim, axle, spacers, swing arm, right rear sets, upper rear alum frame, main frame, wiring harness, solenoid, misc sensors, side stand, shifter/rod, header pipes, misc box of signal parts, left controls,
Discussion Starter #19
I would like to see these parts go to someone who needs them $100 pickup at shop door, osoyoos bc, phone only , no text 1 250 495 344five,
Discussion Starter #20
no call display, if you get the machine, slowly repeat a contact number so I can call you back..... $100 takes the lot.
1 - 20 of 21 Posts
