So I crashed my r6 the other day, under 5mph.. It would not start back up I finally fig. out that my fuel pump was broke so I changed that out and it started but sounds like shit! Its got a damn popping/ticking sound or something to it Idk how to explain it. Does anyone have any sug. on where to even start? It also doesnt sound like it has all of the power it should idk..
Which side did you drop it on? What your idle at? You let it warm up and do the water test on the 4 exhaust to see if maybe the plugs popped off? Take the tank off to see if any loose connections to the air hose? Did you check it at all beside just firing it up and taking a video?
Yes I checked the air box, rechecked the fuel pump to make sure everything was right. timing chain.. Didn't check the plugs or know about the water test or w*e.. my idle is at like 1600, but alot of times I run it at 3000 to ride idle. Anyway I put it in the shop today so hopefully it's nothing major.
