Hi,
my bike won't start anymore. It's an R6 2003.
I already checked the fuses and switches.
Theres also enough fuel and the fuel pump is working.
The spark plugs are new, and there is spark, which I tested on the frame.
Out of the exaust there's coming unburnt fuel fumes, so I think she's getting fuel.
I took out the spark plugs and cleaned them, because they were drenched in gas.
After that I screwed them back in and ran the DIAG mode to test the ignition coil.
From Cylinder #3 i got a very loud backfire, but then nothing happens.
I tried to start the bike another time, but it won't start.
It turns and turns, but doesn't start.
I jumped the battery with my car and tried to push start too, but without luck.
Start spray (do you call it like this? ) didn't help either.
P.S.: I'm from germany, so my english isn't very good. :yuk:
Parts Pimp
Hi,
Your English is better than many americans on the site. LOL
I hope you can get some help from other members regarding your issue.
I would say that it seems like a compression test would be a good idea at this point.
How many miles/km's on the motor?
I with compression being low or gone, I would have that checked or perhaps you are getting too much fuel maybe flooding it.
Thanks so far. :)
30000km = 18000 miles.
Compression test? Hmm have to ask a friend of mine, if he got a compression tester.
Today I held my hand above the intake socket in the airfilter assembly and I think that she's blowing air, instead of sucking.
Isn't that the wrong way? :lmao
CCS #164
anything strange happen on the last ride before it wouldnt start? any noises or knocks?
from your last post it sounds like you busted some valves or something
@moto:
No strange noises etc.
BUT the last day, when she was running I had to start her cold 3 times for just 10 seconds, because I had to move her to another position on street. (it was a hill, so I couldn't simply push her up)
Maybe because of this there was to much fuel on the spark plugs...
