1 - 20 of 38 Posts
Helping a friend part out a bike he just picked up... hes a very good friend of mine and a great guy to work with.. you can pm me or contact him through his website below
http://home.comcast.net/~chidadog/site/
Pictures Of The Bike
04 R6 On Bike Parts
2 Front Rotors $80
Rear Rotor $20
Front Rim Black $200
Rear Rim Black $150
Front Axle $15
Rear Axle $15
Front Spacer $10
Rear Spacers $10
Set of Stock Calipers Front Safety Wired………65
Rear Caliper……………….25
Stock Rear Brake Line…………………………………10
Goodridge SS Front Lines……………………………..40
Front Master with lever and Reservoir………………………..50
Rear Master with Reservoir……………………………20
Triple Tree………100
Forks Setup by CTR Suspensions…..450
Ohlins Rear Shock 46PRXLB missing the adjuster knob on remote $8 replacement $550
Blue GPR Stabilizer with mount……..225
Right Side Throttle Accessory Switch….25
Clutch perch and stock lever……25
Aftermarket Black/Red adjuster Levers…..80
Ignition with key……50 (will work on any r6 and r6s 03+)
Race Prepped Harness ……100
NEW Battery……65
Battery Tray…..25
Gauge Cluster 8970 mi……125
Radiator………125
Engine with 8970 mi Vortex Side Covers 12 track days 2 races since freshen……………750
ECU…….100
Rectifier……75
Throttle Bodies……100
Airbox with Filter……50
Ram Air Tubes………..50
M4 Damaged Exhaust Can Full Exhaust……70
Vortex Clip ons 43mm…………90
Vortex Silver Gas Cap…………..50
Vortex Sprocket 45…………..25
Vortex Front 16T Sproc……….10
Carrier………30
EK 520 RXO Chain…….50
Frame Bill of Sale..MSO never registered…650
Subframe………..150
Swingarm……50
Lower link…..55
Seat…………..50
Stock Fairing Stay………..75
Gas Tank Repaired and ready for paint with pump…150
Track Fairs All Primered and Ready for Paint Upper with zero gravity screen, lower, front fender, supersport tail, rear fender or hugger, front fender…….325
Extra 04 R6 Parts
T Rex Rear Stand - $65
2 New In Box Front Rotors $120
2 used Front Rotors - $80
Used Rear Rotor - $20
Front & Rear Blue Rims - $400 (fit 03-10 R6s and 06-10 R6 rotors different)
New in Box Right SideThrottle Accessory Switch $25
New in Package Graves EG017A Right Side Cover $50
Stock Right Side Case Cover - $35
Silver Vortex Rearsets Shifter heel plate slightly bent but can be fixed in a vice Peg and shifter peg rashed - $150
New Silver Vortex Rearsets - $250
2 New Black Stock Heavy Knurled Pegs - $15
Set of Stock Rearsets Bent shift lever that can easily be bent back - $65
Stock Front Brake Lines - $20
Set of Stock Calipers Front - $50
Rear Caliper-$30
Front Master with Reservoir $45
Stock Brake Lever - $10
2 Stock Clutch Levers - $8 Each $15 For both
Stock Black Clipons - $50
New In Package Gaskets:
Swingarm Seal Guard 5SL-22151-00 ……………….10
Cover Pinion 5SL-15463-00 ……………………………..2
3- Oil Pump Cover 5SL-15456-00 ……………………5 ea
Cam Tensioner Gasket 4FM-12213-00…………….2
Crankcase Cover 2 5SL-15461-00 ……………………5
Crankcase Cover 5SL-15462-00………………………..2
Crankcase Cover 1 5SL-15451-00……………………...3
Vortex Sprockets 46 47 48 49 …………………25 ea
Vortex Front 16T Sprocket……………………………………………….10
Used Track Fairs Upper, Lower, Front Fender……………….250
Blue Tank with Fuel Pump Right side dent rounded dent not sharp…….120
Forks with Ohlins Carts .95 springs $500
New Stock Air Filter…………..20
Open Stock Air Filter………10
K&N Freshened Air Filter……..45
Royersford PA
i believe they all fit the 05 but not sure.. the brake lines might be different.. the GPR and rearsets are the same for sure
Rear Rim Black $150
Front Axle $15
Rear Axle $15
Front Spacer $10
Rear Spacers $10
Triple Tree………100
NEW Battery……65
Battery Tray…..25
Radiator………125
ECU…….100
Rectifier……75
Subframe………..150
Swingarm……50
Lower link…..55
Seat…………..50
Extra 04 R6 Parts
Rear Caliper-$30
Needs more stars
What brand are the plastics? I noticed the price drop...is it still a complete set? (minus the tank)
1 - 20 of 38 Posts
