1 - 10 of 10 Posts
Track Mode!
So i just did the 05 header mod on my 07. I ended up reusing the gaskets. Now when the bike is idling and when riding around, there is a popping noise where the headers mount up to the gaskets. I have block off plates installed and a PC3. I torqued the bolts down to 15 foot pounds with my torque wrench. Could they not be tightened down enough to be causing the popping, or is it because I reused the old gaskets? I'm really confused as to what it is...any help is greatly appriciated. Thanks
Nate
It eliminates the cat. The 05 headers didn't have a cat so it is kinda just like a cheap full exhaust.
Anyway, I figured it out. Just needed new gaskets.
Is the popping on deceleration (roll-off?) if so that happens with decat.
this may be a real dumb question. but is the cat the only difference in the header? like your not gaining anything else right? i have a mid pip on my 09 r6 and just didnt know if there was more of a plus to the 05 header.. runner length etc...
It's pronounced "Tollz"
It's essentially the same thing you have, just probably $100 cheaper :D
I got yami blue balls
Im in the same boat...I have a mid pipe and slip on...any benefit to doing a 05 header swap now?
1 - 10 of 10 Posts
