Any help will be greatly appreciated..my yamaha r6 been sitting for awhile, I just started her up the other day and pulled the clutch in and I have no tension on the clutch lever and she won't go into gear on start...I don't know what to do
UR B-hind Da 8 Ball
Is your clutch cable broken?
Discussion Starter #3
No clutch cable is in good condition, I even loosen the clutch cable from the two bolts, put it in gear and roll it forward engage the clutch from the clutch fork lever itself and still nothing. The wheel still locks and drags, clutch not engaging for nothing
How long has it been sitting ?? I've had similar problems with dirtbike projects where the clutch plates have stuck/siezed and wont release. Have u checked the oil?? Try putting the bike on stand and shifting to 2nd while moving the wheel. Dont use the lever.. try to see if the clutch will break free rocking it back n forward
YZFR6... ooodles of HP
Sounds like stuck plates. Oil creates a glue like joint over time. Rock forward and back in gearwith lever pulled.
  • Like
Reactions: Yamaha is life
