1 - 3 of 3 Posts
when I first got the bike it started up just fine and i let it idle a bit then shut it off and then the next day it would not start up at all. I sprayed some starter fluid in through the front and still nothing. Before I tear into it to see if I am getting spark does anyone know what might have happened or anything to look for? The fuel pump does come on and it turns over just does not fire.
Try holding the throttle 1/3 open and crank it. If it doesnt start its most likely the spark plugs. Its bad to start the engine and shut it down before coming up to temp. Besides the condensation issue the plugs never burn clean.
How about check all your fuses first, then check to see if you have good power and ground going to the fuel pump.with a test light. if you have power and ground then it is probly the pump, or poss the ecu or what ever controls the fuel pump if its not the ecu.
1 - 3 of 3 Posts
