Hi everybody!
This is my official first post on the site and I would like to thank everybody in advance for all the help!
Okay, well I have a 07' YZF-R6 with a full header, cat/servo delete?, and a Voodoo shorty slip on pipe. My bike was running fine for a while except for the low RPM hesitation. I did a little research on the symptoms and found a lot of answers but nothing definitive to my situation, especially now.
At first I could hear a slight skipping/hesitation between 1500-4000rpm but once I opened up the throttle the skip would stop and the bike would take off as if a turbo kicked in! I could deal with it at first BUT here recently, out of nowhere, I went to start my bike one morning and it ran like garbage for a few seconds then cut off and displayed code 36.
I looked it up and found out that it has to do with the #4 coil. Well, I went ahead and pulled all my coils and tested them (primary and secondary) and they were all within spec. But they were cold when I tested them. So I went ahead and actually cleaned all the contact points and switched #1 coil with the #4 coil and put everything back together.
When I started the bike it ran probably better than ever....until I decided to take a late night run to Walmart... When I tried starting ,my bike back up I got the code 36 again!!! So i repeated what I did before; broke it down, cleaned the contact points, and put it back together. Crunk right up...
I expect to see that code 36 pop up anytime now so can somebody please suggest what I should do to fix this? And by fixing this I hope it will correct the low RPM hesitation as well.
And and all help is much appreciated!
Below I attached a pic of a spot I noticed on my number 1 coil that looks like an arc burn spot maybe? Also I should mention these are the same coils I've had since I got the bike. And it has 14k miles according to the odometer.
