1 - 2 of 2 Posts
07 US ECU question
Had a question for the US boys,
As you don't have an imobiliser as we do in the UK, do you know if the ECU supplies +12V on the US spec ones to the Immob Pin?
Reason I ask is I have a US ECU and cut out the immobiliser connector, but wondered if I had to remove the pin from the ecu, or if the US ECU doesn't supply voltage on that pin,
Saves me putting my multimeter on a bunch of tapped up loom.
I did check it but forgot to connect the ECU when I was checking the loom,
Thanks for any info :)
1 - 2 of 2 Posts
