1 - 12 of 12 Posts
sportbike noob
Was told I could mount an 08 up tank on my 06. Said the only difference is under the tank so it clears the different throttle bodies. This true?
When in doubtThrottle out
Not sure the problem would be the two have different air boxes. Of the two if one were bigger it would be the 08+ because of the extra hardware inside.
Wait for someone who knows for sure to chime in.
sportbike noob
Was told by a local racer he runs 08+ on his 07 race bike. He has a few 08 tanks for sale. I'm in need of one
pin it to win it
Different side tank panels Idk if they would line up
sportbike noob
Wonder if he knows if he has an 08 or the 06-07 tank then. He said when its on the bike there is no visual differences. He said the area under the tank is larger to make room for the velocity stacks on 08 up. Having a hard time finding blue 06-07 bodywork and tank. Everyting is 08 up and i dont want to go the china or auctmart route.
The tanks are indeed different and there are some differences in the design of the tank itself on the top and sides not just the void area under. I would make sure that the fuel pump isn't a different orientation so your lines will reach. The trim on the sides are different as well so you will need to get 08+ ones to fit. Didn't you change your airbox to 08+ along with the v-stacks etc...?
sportbike noob
No i never switched anything. I asked a few questions on how to do it but wasnt worth the headache. So i will continue to look for a blue 06-07 tank then.
1 - 12 of 12 Posts
