Looks like some liquid made it's way thru block off plates or the hexagon bolt. Spark plug 1 is to the left of the plate. What could be slowly accumulating from bolt or plate?
This wet spot has been popping up here and there for years at same spot. New gasket? Or normal??
I haven't taken bike out in 3 weeks. I started it up for first time couple days ago til fans turned on twice. I went thru the gears a few times to circulate the oil thru the gears.
After filling tank with stabilizer today I let it run til temp got to 190°. Then I notice oil leaking thru the oil fill cap. There was a decent wet spot around cap and single line going down to bottom of case cover. Like a single drop ran down the case. Never had it that bad before and not sure if it's a problem. My oil level is close to full line.
Any ideas about the 3 issues will help. Thank u
