1 - 2 of 2 Posts
I have an 09 r6 that isn’t starting. The fuel pump is working, just changed spark plugs and all fuses are good. All it will do is crank but not start. I tried push starting it and it sounded like it wanted to start, then i tried starting it again by giving very little throttle and it backfired. Could it be a bad ecu or ignition coils?
Spray starting fluid in the intake and see if it runs on starting fluid. Then you know it's not the ignition system and it's fuel related.
1 - 2 of 2 Posts
